08-07-2016, 04:06 AM | #1 |
Rep 157
F20 replace seats with Sport seats (and repair airbags)
I've found a Sport interior set for my F20. The price was quite low so I took the gamble and start trying to replace the (standard) interior of my F20. If everything goes well and the job is done, I'll bring the car to a leather-installation company.
So.. The rear wasn't a big issue and was done in about 1,5 hours. Now I've started with the frontseats. The first challenge; replacing the airbags. The price of the set was very interesting because of the accident the donor-car had. The side airbags are removed from the seats and the cover is opened where the air-bag came out. See picture below: Does anyone have some ideas how to fix the airbags and the cover? I figured out that the airbags of my standard interior will fit in the Sport seats. So that, I think, isn't the problem. Nb. When I am done I will make a full DYI-guide (with pictures) of the replacement proces of the whole interior |
08-31-2016, 12:46 PM | #2 |
Rep 47
Go to realoem and to the interior part nr.'s. There you should find part numbers for all covers. Choose the one you want and order them through your dealer.
09-21-2016, 04:38 AM | #3 |
Rep 157
All right; the airbags are replaced and the seatcovers are stitched. Next stop; the electronics!
Current seats: Default seats 494 SEAT HEATING F DRIVER/FRONT PASSENGER Bought seats: 481 SPORT SEATS F DRIVER/FRONT PASSENGER 488 LUMBAR SUPPORT DRIVER/FRONT PASSENGER 494 SEAT HEATING F DRIVER/FRONT PASSENGER Does anyone know if the default seats are pin-compatible with these sportseats? And, if necessary, does the car need programming? |
12-07-2016, 08:27 AM | #4 |
Rep 157
It's been a while, but this weekend I've completely installed the seats in my car. There are no errors in the CIC and the seat heating works. The only thing that's not working at the moment are the buttons to de/inflate the lumbar support.
In my previous post I wrote down the options of my car and the donor-car (the one I removed the seats from). The differences are these two options: 481 SPORT SEATS F DRIVER/FRONT PASSENGER 488 LUMBAR SUPPORT DRIVER/FRONT PASSENGER Do you guys thing that if I add these options to the VO the lumbar support will function? If so; how do I add these options to the car? I have eSys and a cable! |
12-08-2016, 10:30 PM | #5 | |
Rep 1,347
01-08-2017, 12:59 AM | #7 | |
Rep 157
Which pin (in the big yellow connector below the seats) do I have to connect to get power on the (lumbar) valve? Last edited by Pepppie; 01-08-2017 at 01:10 AM.. |
01-23-2017, 02:32 AM | #8 |
Rep 157
Next phase done.. Everything is build into the car (see photos). Electronical problems are almost solved. I had to use my own (from the old seats) control module and everything, except the lumbar support, is functioning.
Comparing the two yellow connectors; pin 8 & 16 are not connected in my car, so I have to find what these pins are for. I think it's power for the valve, but my dealer wil tell ;-) Next step; get the leather! I made an appointment in february :-) |
02-18-2017, 07:28 AM | #12 |
Rep 5
Hello!
I'm looking to replace my standard seats with sport ones in my F20. Found a donor wrecked F20 in my country and the seller has agreed to sell me the seats. Currently I have non-electric non-heated standard seats and I'm looking to swap them out for electric heated sport alcantara seats. Apart from the lumbar support not working due to missing power connectors does everything else work? Would the electric seat adjustments work? Plug & play? I don't really care for seat memory etc. I'd just like to move my seats I have automatic climate controls but no seat heating, so I'm missing the button. Is it only that button or are there modules that I'd need to add? Would swapping just the faceplate work (or better, is there a switch hidden under the plastic where the button should be like for rear fogs in some cars)? MarkF20 Have you finished your project? Maybe got lumbar support working? |
02-26-2017, 11:34 AM | #13 |
Rep 12
