08-22-2016, 02:03 PM | #1 |
Rep 8
i3 AM Radio
I was coming up with a list of things I would like to address by recoding on my i3.
The lack of an AM radio is one thing I would like to get changed. Has anyone done that and is the interference caused by the car's electronics really degrade the AM Radio reception? Thanks. |
09-04-2016, 08:35 AM | #3 |
27
Rep 81
You can always try finding an app that will stream AM radio.
e.g. myTuner Radio - Live AM / FM Radio Stations and Online Radios by Appgeneration Software https://appsto.re/us/k5JbF.i |
09-04-2016, 03:40 PM | #4 | |
Rep 2,561
Enable AM radio (HU_NBT module). There is also an option to turn Weather Band radio, but it still doesn't show up in my list of radio sources (though AM does; must be another option that needs to be coded that I haven't found yet). As to other things to modify via coding, here is my rough top-10 list, in no particular order: 1. Enable "hold REX" mode for REX cars to manually turn on REX engine. Also adjust REX auto-kickoff point to lower % of battery (or higher if you need more safety margin) than default 6%. 2. Enable full REX gas tank capacity of 9L vs. US default 8L. 3. Remove all the legal disclaimers and warnings. 4. Remove seat belt warning chimes and warning lights 5. Disable doors and trunk auto-lock upon driving off 6. Set one-push turn signal counter to 5 (from default 3) 7. Code-in enhanced blue-tooth, and allow pairing and full BT and Office functionality at all speeds 8. Enable AM/WB radio 9. Enable rear view camera at all speeds 10. Turn on tire temps and PSI on tire monitor screen 11-99. Enable video playback through Nav screen at all speeds and lots of our misc features... All for free! a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
09-04-2016, 04:01 PM | #5 | |
Rep 8,364
Weather band only works on HU_CIC. |
