08-23-2016, 09:25 PM | #1 |
BimmerPost Supporting Vendor
4922
Rep 115,999
Evolution Racewerks F30 Oil Cooler Released!!! PICS INSIDE!!!
Evolution Racewerks F30 Oil Cooler will be releasing soon!
The details I got so far from ER are as follows... The oil cooler features are as follows: · Large 9"x8"x2" (11"x8"x2" with end tanks) Oil Coolers · Over 350% larger capacity than the factory oil cooler · Optional Aluminum Shrouding to direct airflow through the oil coolers for improved efficiency · Made in USA. · Limited Lifetime Warranty of all manufacturers’ defects. Will come in anodized black or standard finish and there will be an optional shroud kit available. Pictures and more info coming shortly!! Last edited by Mike@N54Tuning.com; 11-23-2016 at 05:23 PM.. |
08-24-2016, 01:07 AM | #2 |
Rep 248
Good stuff!
EXTERIOR: M Sport front bumper/side skirts, M3 rear bumper/fenders, black M3 kidney grilles, cf M3 mirror caps, cf MP trunk spoiler, ACS roof spoiler, side blades, black roof, Grigio Telesto, STANCE: Rotiform SPF 19"s, BC Racing BR coilovers, UUC front end-links, orange calipers, ENGINE: PS1, Wagner FMIC, Borla S-Type exhaust, quad ti tips, VRSF dp/cp, JB4, INTERIOR: ACS pedals, WeatherTech floor & BMW trunk mats
08-24-2016, 03:39 AM | #3 |
Rep 703
Very Nice!
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
08-24-2016, 11:10 AM | #5 |
4922
Rep 115,999
08-24-2016, 11:21 AM | #6 |
Rep 438
Drives: F30 335i M Sport
Awesome!!
08-24-2016, 12:36 PM | #7 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
I had one of these in my previous E92...worked quite well, but I eventually swapped the nylon-braided lines for the braided steel ones. Not sure how the oil lines are routed up to the oil filter/thermostat block on an F30 application, but be really careful to use tie-wraps to keep them from rubbing against anything, particularly the sharp screw ends that secure the plastic underbody shield.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
08-24-2016, 02:55 PM | #8 |
Enthuisiast
93
Rep 423
Sounds nice. I've noticed the oil temps in my F30 in the killer southern heat are around 250*F, never really noticed them getting higher than that.
I assume by the description that it connects to the OEM oil supply. Does it include a thermostatic valve? Is this part suited for cars that are mostly tracked? I've run oil coolers on many of my other cars (mainly Honda & Nissan) since they are really sensitive to oil temps but noticed that the cooler kit I installed on my 370Z kept oil temps very low until the car was driven a while. Even with street driving the temps never really got warm. In for more info...
AW F80 M3 / RAYS / TOYO TIRES / BMS
IG: @hybrid_david |
_bdiddyb_215.00 |
08-29-2016, 09:47 AM | #11 |
Rep 497
They all have oil coolers, it's just most of the non M's have a heat exchanger on the block that is cooled by coolant. I'm hoping they have an adaptor plate to remove the heat exchanger and install an oil to air.
08-29-2016, 02:39 PM | #13 |
BMW Fanatic
331
Rep 1,076
Really hoping this can be installed on originally non-M Sport cars, after getting my catless armytrix exhaust installed, my addiction to its sound is punishing my engine oil.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
08-29-2016, 08:43 PM | #14 |
Rep 1,805
Badass Mike. ER makes nice stuff.
Is the design similar to the dinan one?
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
08-31-2016, 08:54 AM | #15 |
Rep 4,323
Which bumper is it compatible with?
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com |
09-08-2016, 09:33 PM | #16 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
Any updates?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
09-09-2016, 09:44 AM | #17 |
Rep 315
Drives: 2013 335i M Sport
What is the benefit of this?
2013 335i l Estoril Blue | M Sport l MPPK | M Perf Exhaust | M Perf Brakes l Adaptive M Suspension l DAP | DHP | Premium | Tech
My Build -> Mod Journal |
09-11-2016, 12:09 AM | #19 |
515
Rep 1,063
sweet! im ready whenever you are
10-19-2016, 09:42 AM | #21 |
515
Rep 1,063
