08-24-2016, 10:46 PM | #1 |
Rep 309
Race chip ultimate test
Hey what's up guys, so I was looking to buy used tunes from classified section and other sources. I came across a race chip ultimate for really cheap. I couldn't really find much information about it or even videos of it in an f30 335i. It should be coming in the mail sometime next week. Anyone else use race chip? I was gonna go jb4 and I know all the jb4 heads will scold me. I got it cheap and just gonna try it. It claims up 378 hp and 375 torque on stock parts and also improves gas economy. Kinda hard to believe. Only plugs in to two places. Jb4 guys I know about data logging and code reading don't thrash this thread. But yeah going to see how it goes. Seems to be new item so not much using it for our cars. If anyone is using it please chime in. When I get it I will do a review on it. Possibly get it dynoed. Will keep those who are interested updated.
08-25-2016, 04:20 PM | #2 |
BimmerPost Supporting Vendor
24351
Rep 191,163
RC is comparable to the JB stage 1 and not the JB4. Its a stage 1 tune, Jb4 is a stage 2 tune
You will get noticeable power increase
08-30-2016, 12:48 AM | #3 |
Rep 309
So I received the race chip ultimate I bought from someone tonight and did some testing. It's definitely a noticeable increase in HP and torque. I did a hard launch and I can hear my tires scream, sounded like I was losing traction in like the first few gears. I'm on fresh Michellin Pilot Super sports too. I usually drive in sports plus mode and do hard launches and I don't hear my tires normally scream like that. On the freeway it pulls hard and smooth. Power curve seems to be pretty linear. Im thinking of taking it to the dyno to see what it's making and see if it's as advertised. I also got a jb4 stage 2 on the way so I'll see how the race chip compares to the Jb4. To be honest it kinda caught me off guard. But I'll report back again later maybe bumping up some of the settings.
08-30-2016, 09:46 AM | #6 |
Rep 309
08-30-2016, 10:16 AM | #7 | ||
24351
Rep 191,163
If you are looking for stage 2 features like datalogging, there is no benefit to getting the RC over the JB4
FSociety3812.50 |
08-30-2016, 02:16 PM | #8 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
I agree with what has been said.
Use 1 or the other, which JB4 did you order ? because if its not the OBD2 version then you'll have to buy extra stuff etc. Anyways, enjoy the power of RaceChip you can get a cheap bluetooth and connects to an app called TorquePro. And if you want more power and want to add downpipes, add e85, etc then remove RC sell it and install JB4. Looks like you're heading towards a real review of both ? That'll be best that way you see it for yourself what its actually doing on your car and not the next person car lol. Drive racechip for a few weeks, def minimum 300-500 miles, Dyno it ? Then do the same with JB4 and you can get a real comparison how it works on your car. I had RaceChip before in my previous car and now using JB4 in my new car but its not 100% due to revised engine running higher boost than stock N55 etc. So I can help out or give you any tips on both side. N54tech.com is a great forum for JB4 users and Bee Pee is a very well respected user of JB4 and don't know if its him but i think he tried Racechip too.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
08-30-2016, 02:21 PM | #9 |
Rep 309
Thanks guys! I just figure since the both can be connected at the same time and read from the same sensors if I only used jb4 for data logging and no tune I was wondering if it could work so I can data log RCU. Just curious though, to me it make sense lol I'll try it actually. Also I have the latest jb4 with Bluetooth. But will be running the RCU for a bit since it only took me 5 mins to install. I have MPpK and can definitely feel the difference with RCU. Will up the settings soon. It's definitely like a stage 1 tune with a bit of flexibility. I have downpipe and intercooler on the way so I may throw the jb4 once I start to crave more power.
08-30-2016, 02:42 PM | #10 | |
Rep 309
08-30-2016, 03:20 PM | #11 |
Rep 4,526
F30Allen
RCU and jb4 maps 1 and 2 are additive so they will stack on top of mppk tune. Advantage that jb4 map2 has is that it is canbus active hence why it can notional stack more boost (6psi) than map 1 and RCU - both abt 4-4.5psi. Also being canbus enabled, jb4 can take advantage of any bolt ons whereas RCU will be restricted by how DME reacts to changes in hardware or fuelling. Jb4 maps 5 and 6 are absolute so take charge of more sensory info to add optimal boost - much more sophisticated and effective than additive method. BP |
FSociety3812.50 |
08-30-2016, 03:25 PM | #12 | |
Rep 309
08-30-2016, 03:29 PM | #13 | |
Rep 4,526
Thanks for the kind words. I didn't buy RCU before JB4 but I have driven an m235i with TMC (similar to RCU) here in the UK. The albeit short drive in a fully adapted car to TMC was good but lacking up top. F30Allen RCU, TMC stage 1 tunes act as slave to DME so stock trait of boost tailing off beyond 5500rpm is more noticeable than say JB4. If you are happy to short shift then RCU will work as it delivers well in the low to mid range. Jb4 however delivers more across a wider rev range. Absolute maps can tweak or be tweaked to keep boost higher for longer. Look at most jb4 dyno plots and you will see that power curve dips later nearer redline. BP |
08-30-2016, 03:34 PM | #14 | |
IG @bmwF9xG80
3813
Rep 7,593
So OP, I think if you have access to e85 the JB4 will be better off. But you also have to find out what do you want out of your car.
08-30-2016, 03:38 PM | #15 | |
Rep 4,526
If wanting to go beyond that with low grade gas then best talk to Enzo Performance or Hex Engineering or PTF - bootmod3 developers BP |
08-30-2016, 03:47 PM | #16 |
IG @bmwF9xG80
3813
Rep 7,593
MissionPerformance is also in California also good option
apexlocator M5 got tuned by them Bmw doubles 535 ocN55 m235 as well Def proTUNING Freaks BM3 I don't think VF-Engineering HEX Tune is out for N55 yet ?
08-30-2016, 03:59 PM | #17 | ||
Rep 309
08-30-2016, 04:54 PM | #18 |
Rep 4,526
F30Allen
Is your car EWG and your jb4 installed with additional ewg harness ? If so, map5 with 101 octane gas will be an absolute hoot. Log it and check how timing and avg ign looks then flip to map 7 - tried it with octane booster added to the tank and map7 is hilarious. Too much for our busy roads here in the UK. BP |
08-30-2016, 10:26 PM | #19 | |
Rep 309
If I changed my fuel lines from fuel it would I be able to run small percentage of e85 with no problem? Or would I run in to parts deteriorating? There's a station close by and I'm tempted but scared lol |
