08-27-2016, 09:15 PM | #1 |
Rep 1,805
Who's running JB4 / DP /Pure stage 2 / 92-93 Gas
Real world reviews?
How do you like it? Civilized? Sound? Should be on this set-up in a month or so....
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
08-27-2016, 10:56 PM | #2 |
Rep 5,776
I'm Jb4, DP and e85 and love the power. Upgrading the turbo has to be just blistering fast.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
08-28-2016, 07:29 AM | #3 |
Rep 1,805
I plan on running normal gas. Have you just used e85 from the start?
How were the results on normal gas?
08-28-2016, 09:46 AM | #4 |
Rep 5,776
08-28-2016, 11:21 AM | #6 |
Rep 5,776
Your going to find more people with these type of mods on n54tech.
wakeofdeath70.50 |
08-29-2016, 03:04 PM | #7 |
Rep 271
Attached is the dyno result of my car on 93 octane FBO; Pure Stage 2 turbo; Fuel-it stg 2 lpfp and stock tune. JB4, map 6. I have seen better numbers on other cars with the same mods. My car is currently still undergoing fine tuning though.
Vic
2021 M550i
BMS Pedal tuner JB4 Last edited by BimmerFan; 08-29-2016 at 03:13 PM.. |
08-29-2016, 08:13 PM | #8 |
Rep 1,805
I do.... it's everywhere in Minnesota. I just dont want to have to mess around with it...
08-29-2016, 08:14 PM | #9 | |
Rep 1,805
Thanks Vic! Not great at reading these... does that mean your car is putting down 413HP at the wheels? Im a Dyno newb
08-29-2016, 08:19 PM | #10 |
Rep 5,776
Dude..mess around..don't be scared..trust me..put 3 gal. in and the rest 91 or 93...whatever you have. Put on Map 5 and give some rips. No risk...thank me later.
08-29-2016, 08:34 PM | #11 | |
BimmerPost Supporting Vendor
24366
Rep 191,194
Start with going FBO first and if still want more power we can discuss the next step
jgoens3787.50 |
08-29-2016, 08:41 PM | #12 | |
Rep 1,805
I've just never been good at reading those graphs. Just wanted to hear what other members thought of their set-ups! Cheers, Pete
08-29-2016, 08:42 PM | #13 | |
Rep 1,805
Jesus ok I can do that.. Is E85 just a major game changer?
08-29-2016, 08:43 PM | #14 | |
24366
Rep 191,194
As soon as i bought the car, i went FBO with a stage 2 fuel pump
08-29-2016, 08:45 PM | #15 | |
Rep 1,805
It's sad, my car is a 2014 with 6,500 miles on it... I spent countless hours reading about everyones mods and try to nail it on the first time. Major passion for me. only fuk up was the enzo tune that they couldn't get to work with car?? go figure.
08-29-2016, 08:47 PM | #16 |
Rep 1,805
So if I play around with 2-3 gallons of E-85, do I need to do any other upgrades to the car for that type of gas?
08-29-2016, 08:47 PM | #17 |
24366
Rep 191,194
What was the problem with Enzo tune?
08-29-2016, 08:49 PM | #18 | |
24366
Rep 191,194
If equipped with the FlexFuel add on connector E85 mixtures may be used with pneumatic wastegate x28i models and the x20i electronic wastegate models. E85 is NOT supported for the electronic wastegate x28i model. When using E85 a mixture of no more than 40% is suggested. As long as it is suggested to be used on your own car i would start with a very small mix 2 gallons and check the datalogs to make sure everything is running fine
08-29-2016, 08:58 PM | #19 |
Rep 1,805
I don't want to bad talk enzo, they are very professional and treated me right. I'm pretty sure i'm the only guy this happened too.
Initial Report to Imola and ENZO I drove the car home the other night. There is significant hesitation at all RPMs. The best way I can describe it; the car seems to hit a redline at lets say 3,000 RPMs, the engine completely cuts out and RPMs will not climb and further. While this is happening, the engine will bounce on whatever RPM it’s currently on very quickly, like your hitting the max RPM on redline without shifting. This will continue until I let off of the gas. I was able to reproduce the same results on pretty much every pull. The range of RPMs didn’t seem to make a difference, i was able to reproduce it at 3200 and 5500 RMPS. If I babied the car, there didn’t seem to be any mis-fires, it happened under medium to high levels of load. Further diagnoses by Imola. Test drove vehicle and found it behaves as noted after DME reinstallation. Intermittently, at about 4000-5000 rpm, usually from a rolling start, it shudders as if ignition misfiring or ignition interrupt (as when shifting). This can last for almost a second. Does not store a fault when it occurs. There is a fault stored, but it does not seem to be in coincidence with the perceived problem: 102A22-Hot film air-mass meter, operating range: Air mass too high, occurred once at 7086 miles at 6800 rpm at 1107 kg/h air mass, 100% accelerator pedal angle. Test drove again fault recurred (total twice stored) with no apparent problem or fault indicator. Decided to check for possible intake leaks. Found no problems upon visual inspection. No leaks found upon smoke and boost leak tests. Fault information specifies that the fault is stored when the air mass exceeds 1050 kg/h, which seems likely with increased engine power/air flow. It would seem that this fault may not be related to this drivability problem and may be "normal" for a tuned DME. Suspect calibration/coordination error between DME and EGS. Video of it in action. https://www.youtube.com/watch?v=r8L4...ature=youtu.be I was pretty bummed out.. when it did run good, the car was a beast. Just wasn't meant to be.
08-29-2016, 09:00 PM | #20 | |
Rep 1,805
08-29-2016, 09:01 PM | #22 | |
24366
Rep 191,194
Sorry about your bad experience
