Oil temperature hit 260
09-13-2016, 12:34 PM | #1 |
Rep 149
Hey all I have a e92 lci and my oil temperature just hit 260 it didn't go over or anything but I was wondering if that's a sign or a symptom of a issue occurring? I've heard from a couple people that bmw tend to run hot but I guess that seems to hot for mental comfort to me. I did search the forum but couldn't reach any definitive answer
09-13-2016, 12:41 PM | #2 |
Rep 281
Same, mine hits 260 on average days and depending on how I drive it. Only way to control that is with an oil cooler. For now I don't have one as its getting colder in my state. But my car hits 260 on normal days.
09-13-2016, 02:29 PM | #4 | |
Rep 775
260ºF is probably okay for an N52 on a hot day though. But that's about the upper limit of my comfort zone. |
09-13-2016, 04:12 PM | #7 |
Rep 385
That's a common misconception. In normal use the oil's viscosity improvers actually thicken the oil as its temperature increased in order to maintain proper protection.
http://www.belray.com/what-exactly-d...ignations-mean
2012 E91 MSPORT • ST COILOVERS • TSW BATHURST |
09-13-2016, 04:17 PM | #8 | |
Rep 657
09-13-2016, 09:27 PM | #10 | |
Rep 1,286
2012 Jet Black 328i Coupe / ESS Tuning Gen. 2 Supercharger / Evolution Racewerks Oil Cooler / BMS Oil Catch Can / BMW Performance Exhaust with Dinan Y Pipe / Eibach Pro Kit Springs / Koni FSD Shocks / MFactory LSD & Differential Bushings / Performance Rear Trailing Arms / BMW Performance Strut Brace / Stop Tech Slotted Rotors / Hawk HPS 5.0 / SS Brake Lines / Brass Guide Pins / M3 Front Control Arms, 28 MM FSB, Engine Cowl, and DCT Paddle Shifters / Michelin PSS / APEX ARC-8
Soul_Glo13381.50 |
09-18-2016, 07:42 AM | #14 | |
Rep 775
You can see some typical viscosity curves of various oil grades here: http://www.viscopedia.com/viscosity-...ine-oil/#c1290 The charts only go to 100ºC, but they won't suddenly reverse at 125ºC Last edited by Terraphantm; 10-27-2017 at 08:42 AM.. |
09-18-2016, 12:12 PM | #15 | |
Rep 385
09-18-2016, 01:17 PM | #16 | |
Rep 775
The oil absolutely will be thinner at 260 vs 250 vs 240, 230, etc. |
09-19-2016, 11:05 AM | #17 | ||
Rep 385
09-19-2016, 11:40 AM | #18 |
Rep 7,215
no. that is only up to a point. The idea is you have a light oil when it's cold (0w) so that lubrication can get through the motor during startup. Once the oil warms up, the modifiers do increase viscosity to a point (normal operating temp).
However, definitely does NOT thicken at 260f. That is ridiculous. If it did, people would not run oil coolers - the truth is at high temps, not only can the oil itself break down (including additives), but the chain of molecules becomes stretched and the oil thins. This can result in low pressure which is dangerous for the engine especially if you are beating on it at the track. |
09-19-2016, 02:24 PM | #19 | |
Rep 775
Take a look at the spec sheet for this 5w40 oil: http://msdspds.castrol.com/bpglis/Fu...PXE-A5TQLE.pdf Notice the Viscosity (kinematic) @ 40ºC and @100ºC. At 40ºC, it's 84 cSt. And 100ºC it's 14.0 cSt. The oil is significantly thinner at 100ºC despite having viscosity improvers. That trend does not reverse (at least until the oil gets so hot that it starts undergoing chemical reactions and forms a different product altogether). |
09-19-2016, 03:00 PM | #20 | |||
Rep 385
09-19-2016, 03:37 PM | #22 | |
Rep 775
The only numbers I've referenced have been temperatures which engines see every day. |
