Catch can install; what size threads should I use?
09-17-2016, 03:53 PM | #1 |
Rep 1,247
I've bought a catch can to fit to my N57 330d. The connectors on the catch can are 15mm O/Dand I've bought a new PCV pipe and cut the ends off.
The I/D of the fittings I want to attach the fittings into is 16mm. I bought some 16mm barbs but the thread doesn't bite so I probably need 17 or 18mm. Most threaded barbs/hosetails seem to be in inches. The nearest common size seems to be 3/8" but this only correlates to 16.66mm so still likely too small. How tapered are BSPT threads and could I go up to say a 1/2" BSPT thread which would give enough initial taper to fit the 16mm diameter fitting? I'm so confused! |
09-18-2016, 07:39 AM | #2 |
Rep 3,200
Drives: E92 325i MSport Coupe
Got my OCC connectors here:
http://www.advancedfluidsolutions.co...iners-60-c.asp you should find what you need...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Len_Beach188.00 |
09-19-2016, 12:54 PM | #3 | |
Rep 1,247
