09-23-2016, 03:04 PM | #1 |
not good, but bad
333
Rep 361
Is this "oil blow through"?
Hi all,
During the install of a new intake on my car I noticed this in the flex tube part of my intake. Is this the "oil blow through" I've read about that the Oil Catch Can supposedly stops from happening? Is this any cause for concern? I took a long q-tip and was able to get a little of it on there, smells and looks like motor oil for sure. Most of it was dried up but there was some fresh on there. [IMG]http://*************/wp-content/uploads/2016/09/IMG_0400-e1474660981901.jpg[/IMG] Thanks!
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
09-23-2016, 06:32 PM | #2 | |
Dejan
1755
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
FBO-PS1 and stuff
09-24-2016, 10:21 AM | #3 |
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
The oil is from the Positive Crankcase Ventilation (PCV) system that vents back into the intake tract along with a small amount of oil from the turbo bearings. It would take a VERY long time to have enough oil come through to cause a low-oil indicator, but it's not anything to be concerned about. This system has been improved greatly in the N55 and B58 engines in the F-chassis cars, enough so that an oil catch-can is not necessary.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
F32Fleet3607.50 |
09-24-2016, 02:32 PM | #4 | |
Rep 10,373
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
09-24-2016, 10:29 PM | #5 |
Rep 1,782
I have had it come up 2 times so far since I have owned my car. I got my F30 in December of 2015. Road tripped it a few times.
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
09-25-2016, 12:32 AM | #6 |
not good, but bad
333
Rep 361
Thanks for the responses all, appreciate it.
I was really just curious about it. It this what also contributes to the needing of walnut blasting the valve heads? Thanks!
09-25-2016, 09:06 AM | #7 |
Rep 1,782
That's mainly due to the direct injection. The injectors squirt the fuel directly into the cylinder versus going through the intake manifold first. That's why we have to walnut blast. Cylinders get nasty from fuel hitting them directly from what I understand.
09-25-2016, 11:36 AM | #8 | |
Dejan
1755
Rep 4,197
FBO-PS1 and stuff
09-25-2016, 10:09 PM | #9 | |
Rep 884
The walnut blasting is to remove carbon buildup on the underside of the intake valves as the valves are NOT being washed by atomized fuel as they would be in a typical port fuel injection system. |
09-26-2016, 10:34 AM | #10 |
Rep 674
Unless the motor is hurt, and getting lots of blow by (cylinder compression making it past the piston rings into the crankcase) the amount of oil making it back to the intake track is very minimal and not a concern.
Or if you're pushing significantly more power than stock (+ ~200hp) which in turn creates more cylinder pressure and blow by, a catch can is typically not needed. Love the direct injection response, btw |
