10-02-2016, 11:57 AM | #1 |
Rep 352
Forge BOV Kit Fitment?
I just saw a thread on the m235 forums where they installed the following BOV (Atmospheric vent) kit.
http://www.forgemotorsport.com/Blow_...uct--1358.html The kit is made for the N55 engine but the site list that the only compatible vehicles is the m235i.. Since I have an f30 (n55)... Will this fit as well? does anyone know a reason why would this not fit another n55? Thanks! |
10-02-2016, 12:16 PM | #2 |
Rep 2,962
Subscribing because I'm having potential DV issues
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
10-02-2016, 03:29 PM | #3 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
I sent them an email. I'm intrigued.
Chicken_Joe608.00 |
10-02-2016, 06:36 PM | #4 |
Rep 1,782
Sub'd
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
10-02-2016, 07:40 PM | #6 |
Rep 1,782
Hopefully someone can make a Stage Omar turbo to fit our cars along with this
10-02-2016, 07:42 PM | #7 |
515
Rep 1,063
mbanks211275.50 Chicken_Joe608.00 |
10-02-2016, 07:45 PM | #8 | |
Rep 2,962
stxf3094.00 |
10-02-2016, 07:47 PM | #9 |
Rep 1,782
10-02-2016, 09:19 PM | #11 |
Rep 352
10-03-2016, 08:42 AM | #12 |
515
Rep 1,063
pretty impressive lol, ill be there in the next few months
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
Chicken_Joe608.00 |
10-04-2016, 07:09 AM | #15 |
515
Rep 1,063
Forge said it fits, I asked for more details tho, like if they think it's an improvement over the DV+ and if so, what is their reasoning? And how does it function differently than the DV+.
kevinjt151.50 |
10-04-2016, 07:51 AM | #16 |
Rep 352
10-04-2016, 08:39 AM | #17 |
Rep 963
does anyone know if this leads to issues down the road? my last car was a VW GLI with a 2.0T and it also used a DV, but it was well known that BOVs on that car were not a good idea:
"DV (diverter valve) takes the remaining air from the turbo after throttle body closes and "diverts" it back into the air intake. On a VW, This air has already been pre-measured by the MAF and the ECU expects that air to be there. If the air is no longer there the ECU will not know that and add fuel for air that is no longer in the system. This will cause your ECU to log a rich code (too much fuel in the fuel/air mixture) and make it lean out (add more air) your fuel air mixture to compensate for this loss in air due to the BOV and it overall ruins your entire fuel map." does the MAF on the N55 work similarly at all and therefore a BOV would not be such a good idea?? |
10-04-2016, 11:58 AM | #19 |
515
Rep 1,063
10-06-2016, 08:29 AM | #20 | |
Rep 963
Can anyone with technical knowledge of the N55 confirm?
10-06-2016, 10:51 AM | #21 |
3441
Rep 79,211
Drives: C6 Z06, 09 335i, 10 335xi
The Forge DV makes sense if you are looking for the atmospheric aspect otherwise the GFB DV+ can be had for significantly less and you'll still reap the benefits of improved response, a touch more sound and it fixes any small leaks that them OEM is prone to have as it ages.
I don't think it matters because the recirculated or vented air is not metered by the MAF for fueling purposes. This was very common on the WRX platform too not so much in the BMW world since that particular air isn't metered. |
kevinjt151.50 |
10-09-2016, 05:37 PM | #22 |
Rep 1,782
I wish I could make my car Ssssssssstu tu tu tu
kevinjt151.50 |
