squealing and rough idle
10-04-2016, 06:55 PM | #1 |
Cuba
81
Rep 1,676
So as of a few months ago when I start my car to leave to work or leave home from work there will be a squealing when I am stopped at a light or low rpms. There is also a slightly rough idle where rpms drop from 600 to 500 causing a slight shake in the car.
This does not happen all the time, maybe once every week or week and a half. I recently changed the spark plugs this past weekend (has been happening before this). Today at the stoplight it was happening and I turned the car off and back on and it went away for the rest of the drive. The rough idle only happens in combination with the squealing. Any ideas what this could be? I was researching about the PCV valve but would like some other areas to check before spending $350 for a valve cover. Thanks
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
10-04-2016, 09:09 PM | #2 |
Rep 377
I have the same exact problem!! Mine used to dip to 500 and vibrated badly which I solved by cleaning the vanos solenoids. It won't dip below 600 anymore but will still sometimes run rough and cause slight vibration. I pinpointed my noise to the exhaust. It comes from around where the headers meet the mid pipe but not exactly. When you're idling, check under the car to see if you hear it better. I went through some exhaust set ups which affected this.
128i and 135i come with a large rubber vibration dampenener on the muffler, which you're supposed to move over to the PE that I forgot and never did. Stock headers also have a vibration dampener. Stock headers + PE exhaust (no vibration dampener) = no squeal AA headers + PE exhaust (no vibration dampener) = squeal AA headers + AA exhaust = squeal AA Headers + 135i exhaust (with vibration dampener) = no squeal So I know it's from idle vibrations shaking the exhaust, but I'm not sure what exactly is making it squeal. That's about all my detective work so far Last edited by Suhb; 10-04-2016 at 09:32 PM.. |
10-10-2016, 04:38 PM | #5 |
Cuba
81
Rep 1,676
Happened again today and I tried to open the engine oil cap and could not open it while idling.
10-10-2016, 04:40 PM | #6 | |
Cuba
81
Rep 1,676
Dont believe it is exhaust related, showing symptoms of the PCV valve. Squealing this morning and tried to open the engine oil cap and was not able to due to the vacuum.
10-11-2016, 11:11 AM | #7 |
Yiannis Gazis
97
Rep 734
Drives: 2007 328xi
Check vanos solenoids. Prob need to replace them
2nd Bimmer - 2013 335is | Alpine White | DCT | Loaded
1st Bimmer - 2007 328xi | SGM | e90 | Premium | Navi | Gloss black trim | Cold | AA headers | 3 stage intake manifold | AA stage 3 tune | AFE stage 2 intake | Cyba Scoops | OEM Blacklines | OEM LCI mtech front bumper | OEM LCI hood | OEM gloss black kidney grills | Orion v4 LED halos with blackout headlights | Valentine 1 Radar | Sport wheel with paddles | kw v1 coilovers | VMR 710 | Continental ExtremeContact DW | |
10-11-2016, 11:12 AM | #8 | |
Cuba
81
Rep 1,676
10-11-2016, 09:38 PM | #9 |
Cuba
81
Rep 1,676
Images from tonight. Not entirely sure what i am looking at, so not sure if they are bad or not.
Also pulled out the plug on the eccentric shaft sensor to see if there was any oil inside and there was not
10-13-2016, 05:04 AM | #10 |
Rep 3,200
Drives: E92 325i MSport Coupe
Don't think it's anything to do with Vanos. Inability to remove the oil filler cap at idle is a classic symptom of crankcase breather problems...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
10-13-2016, 08:15 AM | #11 | |
Cuba
81
Rep 1,676
10-14-2016, 10:44 AM | #12 | |
Yiannis Gazis
97
Rep 734
Drives: 2007 328xi
10-14-2016, 10:52 AM | #13 | ||
Cuba
81
Rep 1,676
10-18-2016, 09:53 AM | #14 | ||
Cuba
81
Rep 1,676
06-27-2018, 08:07 PM | #16 |
Cuba
81
Rep 1,676
I changed the oil and it squealed once, I shut the car off and back on and it has been good ever since. I now change the oil every 7500-8000 miles instead of the 15k BMW says. My belief is that oil was getting gummed up and keeping the valve open
