10-09-2016, 07:29 PM | #1 |
Rep 969
2013 335i N55 Dyno 400whp, 473wtrq STOCK TURBO. With JB4 different map comparisons!!
Hi guys,
I was able to secure some dyno time this weekend and I threw my 2013 335i M Sport on for some testing. Overall, I was extremely pleased on how my car ran and it even out performed some of the figures I had in my head. I was able to hit that 400whp club on stock turbo I will get to the good stuff first. Car is equipped with a 6 speed MT, full bolt ons (minus FMIC), running ~e40 mix and JB4. Best pull was 400whp, 473wtrq. I baselined on this SAME dyno bone stock with 273whp, 298wtrq. These are gains of 127whp and 175wtrq. Here is the video of the pull: Here is the log from the best pull. Running map 7 I did another dyno run directly after (still on map 7)...numbers were slightly lower due to heat soak. Baseline Run FBO vs. Map 7. STOCK DYNO SHEET --------------------------------------------------- After this I decided to do some independent dyno testing with my JB4. *Please note the below runs contained e40 (aside from stock baseline number which had 93 pump gas.) If you are running straight pump gas, expect the numbers to be lower. Here are the results: Bone stock: 273whp, 298wtrq FBO Stock Boost: 311whp, 322wtrq Map 1: 354whp, 384wtrq Map 2: 356whp, 424wtrq Map 5: 376whp, 396wtrq Map 7: 400whp, 473wtrq |
10-09-2016, 07:35 PM | #2 |
Rep 262
Drives: 2013 BMW 335i M-Sport
F30_SixSpeed thats awesome!!! I'm starting to play with e85 right now and trying to find a good guide on how to go about it. Do you have any recommendations? Also do you see any crazy AFR's? My logs are showing me in the 20's running E30.
F30_SixSpeed1170.50 |
10-09-2016, 07:51 PM | #3 |
Rep 939
very nice. what did you have your FOL at?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
F30_SixSpeed1170.50 AC79259.50 |
10-09-2016, 08:05 PM | #4 | |
Rep 969
BTW... I saw your other thread on N54. I think you were looking at it wrong. Didn't look too bad from the logs you sent. Best is to start with 3 or so gallons of e85, log it... if everything looks good add a little more moving forward. PWG cars can run higher mixes EWG cars. Thank you sir. FOL is set to 90. |
10-09-2016, 08:36 PM | #5 | |
Rep 262
10-09-2016, 09:05 PM | #6 | |
Rep 969
I also run map 1 or 5 for the most part daily driving which should make it a bit easier day to day. |
sdhasher21127.50 |
10-09-2016, 09:31 PM | #7 |
Rep 462
Nice numbers! was this on a mustang dyno or ?
10-09-2016, 11:21 PM | #9 |
Rep 720
Nice car, nice results
10-10-2016, 12:32 AM | #10 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
nice!!
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
10-10-2016, 02:33 AM | #12 |
Rep 2,577
Congrats! Great results!
What's the boost with 400WHP if you don't mind? And I am assuming the best you get with 93 octane is 356whp on map 2? What's the boost then?
Lemania 2320
10-10-2016, 07:50 AM | #13 | |
Rep 969
Map 1 commands 4 psi over stock and map 2 commands 6 psi over stock... so roughly 12 & 14 PSI for those lower maps, though they may be user dependent considering what else is done to the car (DP, exhaust, intake, etc.) All the runs were using around 6 gallons of e85 mixed with 93, its roughly an e40 mixture. I would expect lower numbers on just 93 pump gas. |
10-10-2016, 12:02 PM | #14 |
Rep 133
How many miles do you have on your stock clutch? I just tried doing a dyno with FBO, 70% meth, 94 Oct Gas on Map 7 and my clutch was slipping during 3.5-4k RPM. The guy said the clutch started slipping where tq was at 450+.
I have a 2014 335i RWD so its EWG with 62,000km. Thinking if my stock clutch is too worn or I just need a better clutch like Spec 2+ to hold that power. |
10-11-2016, 12:01 AM | #16 |
Rep 248
Sweet!!!
EXTERIOR: M Sport front bumper/side skirts, M3 rear bumper/fenders, black M3 kidney grilles, cf M3 mirror caps, cf MP trunk spoiler, ACS roof spoiler, side blades, black roof, Grigio Telesto, STANCE: Rotiform SPF 19"s, BC Racing BR coilovers, UUC front end-links, orange calipers, ENGINE: PS1, Wagner FMIC, Borla S-Type exhaust, quad ti tips, VRSF dp/cp, JB4, INTERIOR: ACS pedals, WeatherTech floor & BMW trunk mats
10-11-2016, 08:45 AM | #17 |
IG: AndrewRodriiguez_
86
Rep 281
Drives: 2013 335i x Drive Sport 6M/T
Garage List 2013 BMW 335xi [0.00]
2002 Lexus IS300 [0.00] 2004 Subaru WRX (SOLD) [0.00] 2010 Honda Civic Si ... [0.00] |
Awesome!! would love to reach similar numbers.
10-11-2016, 10:56 AM | #18 | |
Rep 969
Thanks all. Car pulls pretty good with this setup
MARC20102.00 |
10-11-2016, 12:28 PM | #19 |
Rep 271
Nice. You have your HPFP to thank for that.
2021 M550i
BMS Pedal tuner JB4 |
obriennathaniel514.50 |
10-12-2016, 02:10 PM | #21 |
BimmerPost Supporting Vendor
24354
Rep 191,163
Really good numbers!!
Please post logs for all maps .. Upload it to datazap.me
10-13-2016, 08:13 AM | #22 | |
Rep 969
http://www.n54tech.com/forums/showpo...7&postcount=12 |
FSociety3812.50 |
