Valve Cover.. I know, another one.
10-28-2016, 11:26 AM | #1 |
Rep 2,120
Hey Guys,
Did an entire overhaul of the Valve Cover 4 months ago. VCG, VG, Eccentric shaft censor, blah blah blah. Inspected the plactic cover and no cracks, awesome. last week had misfires due to pooled up oil around plugs in cylinder 2,3,4,5. Replaced all plugs and 1 bad coil and cleaned well. Brought the car in for service and the master tech is saying the cover is cracked (138k miles) My question is does the N52 330 alu VC (11 12 7 548 274) fit on the N51? Im assuming yes. Ill just need to pick up the the ALU bolts since the steel ones will destroy the threads right? Sorry, i searched on here but couldnt find a thread with info. Evan@Tischer I will order the part from you guys if it will work. thanks all
BMW CCA # 473001
10-28-2016, 11:32 AM | #2 | |
Rep 503
// 328i E92 // N52 // Muffler Delete // K&N Drop In // Charcoal Delete // RGBW LED Halos |
10-28-2016, 03:33 PM | #3 |
Rep 2,120
thanks dude, they couldnt confirm but Tischer is thinking it should fit. I may just order both incase and report back.
BMW CCA # 473001
10-29-2016, 10:44 AM | #5 |
Rep 49
I wouldn't do a swap for the aluminum valve cover. You are going to have to change the oil pan and have to buy all the hoses along with the oil separator. It will be cheaper to just replace the plastic valve cover.
10-29-2016, 03:20 PM | #6 |
Rep 2,109
If he has a cast aluminum oil pan it would have the threaded oil return line hole but just plugged, so oil pan wouldn't need replacement in that case. I believe the manual transmission and RWD ones had sheet metal oil pans. All XI's regardless of transmission and auto transmission RWD I believe came with cast aluminum oil pans.
But even with all the rest needed gaskets, oil separator and related hoses it would come easily twice the price of a single plastic valve cover that comes with all the gaskets on it. The engine harness may not fit well also. Also the outside oil separator under the manifold makes any work involving removal of intake manifold a pain. |
11-02-2016, 06:48 AM | #7 | |
Rep 2,120
Hope it last another 135k
BMW CCA # 473001
