Wheel Lifters
11-04-2016, 05:09 AM | #1 |
Rep 5,050
Wheel Lifters
I'm getting older with a bad back, and wheels are getting heavier, so I'm not looking forward to swapping the wheels over to the winter set tomorrow. I've looked around for a wheel lifter but the only ones I can find are the 'Ezy Wheel Lifter', which was an brilliant Australian invention that seems to have bitten the dust, and the Sealey 'Tyre & Wheel Handling Dolly' which looks a bit pathetic. Does anyone use or know of anything similar that doesn't cost as much as the wheels?
PS. I've got a couple of those screw in pegs that replace the wheels bolts, which are a help but not a solution. |
11-04-2016, 05:39 AM | #2 |
Rep 585
Could this be of any use? clicky wheel dolly
If its broke.. Mod it! if not, mod it anyway!
11-04-2016, 07:13 AM | #4 |
Rep 972
why dont you ask your garage to do it for you? local tyre shop charges £5 a wheel, my local garage i go to would do it for free.
2016 M140i
07 E90 335i: JB4, Trebila BEF, BMS DCI, VRSF DPs, Scoops, 19" CSL Reps, 5" ETS FMIC, VTT Inlets, BMS CP, HKS BOV, BMS Meth Injection - sold |
11-04-2016, 08:44 AM | #6 |
Rep 5,050
imy & John 320d: Thanks for the suggestion, I may well finish up doing that, but I'd still like a wheel lifter for other jobs that I need the wheels off for.
11-22-2016, 09:12 PM | #7 |
Rep 3,016
Fitted my winter wheel/tyre set today and found the job much easier by jacking each wheel until it was only just off the ground - hardly any lifting effort required.
11-23-2016, 01:38 PM | #9 | |
Rep 3,016
Having said all that, the wheel dolly you mentioned does look pretty good, please let me know how you get on with it. I notice that you use some threaded posts and that would certainly make the alignment a lot easier - please could you let me know where you bought them? |
11-23-2016, 04:07 PM | #10 |
Rep 5,050
From memory I bought the threaded posts oh eBay, but to be honest I didn't bother using then this time, just dropped the new wheel onto the lifter, a short pump to lift it to the correct height, rotated it till the holes lined up, then shoved the wheel into place. There's no need to struggle getting the first bolt in place either as the wheel threatens to fall off, just let go and the wheel stays where it is while you screw a bolt in at your leisure. It really was a breeze.
11-24-2016, 02:59 AM | #11 |
Rep 3,200
Drives: E92 325i MSport Coupe
I've found a wheel pin really for making the job of refitting a wheel easier:
http://www.burgertuning.com/wheel_hanger_pin_BMW.html http://www.ebay.co.uk/itm/BMW-Tool-K...IAAOSwmtJXbVm4 Although you still have to raise the wheel at first, once you've located it on the pin, you no longer have to support the weight of the wheel while securing the wheel bolts.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
11-26-2016, 08:15 AM | #12 |
Rep 3,016
Found these:http://www.ebay.co.uk/itm/331579607229
11-26-2016, 08:17 AM | #13 | |
Rep 3,016
11-26-2016, 03:05 PM | #14 |
Rep 5,050
