Losing oil under boost!!!
11-25-2016, 08:39 PM | #1 |
Rep 26
Drives: 2015 BMW M4
I just replaced the oil filter housing/oil cooler gaskets a few weeks ago as I noticed a lot of gunk on the front of the engine and I have already shredded two belts. I noticed that there was still oil on the top of the filter housing. i figured the cap was old and seeping oil through the threads under higher oil pressures so I replaced that also.
I just did a road trip down to Austin for Thanksgiving (I live in DFW area). I decided to check the oil level on the dash about half way through the trip. It showed I was half a quart low. I happened to check it before we left and it was completely full as I just did an oil change a few days before the trip. Here is the weird part...I have noticed this before. It is always after spirited highway driving when under sustained boost (i.e. in DS or manual mode and passing traffic). If I am just running around town and staying out of boost (for the most part), I don't notice any oil level drop. On the way back home it was 3/4 of a quart low after getting back on the highway and checking it again with some boost pulls through traffic. I pulled over and topped it off, however, it lost another 1/4 quart by the time I pulled in the driveway. WTH is going on!!!??? Has anyone ever heard of this happening? |
11-25-2016, 09:01 PM | #2 |
Rep 386
Drives: 08 535xi 11 328xi
is the car actually telling you to add or are adding because it shows a little low. I never check the oil level. if It tells me to add I will. 1 quart or less low will not hurt the engine at all. you could have a faulty oil level sensor.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
11-26-2016, 07:54 AM | #3 |
Rep 952
You may not be losing oil, it just may not have made it back to the pan yet to be measured. You should try to measure you oil under the same conditions each time, not hot one time, cold another, after heavy driving, etc...
For example, on the new 2.7 ford V6 turbo engine in the F150, it takes about 15 minutes for the oil to return to the pan after the engine is shut down. Before you jump to a conclusion here, try measure the oil after the car has been sitting 10 minutes and see if you still show losing oil consistently.
bone stock
11-26-2016, 08:45 AM | #4 |
Rep 666
Just to be safe, only top up the oil when the car gives you the low oil warning. This will prevent overfills.
If it's not your oil level sensor and it only happens under boost, your turbo's seals may be on their way out. How many miles? Original turbos?
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
12-05-2016, 01:12 PM | #5 | |
Rep 26
Drives: 2015 BMW M4
I just find it strange that after an oil change the oil level shows max. After about 100 miles of highway driving where driving more on the spirited side, it shows low. Unfortunately, the oil level shows the spinning clock until the engine is at operating temperature. |
12-05-2016, 01:13 PM | #6 |
Rep 26
Drives: 2015 BMW M4
Also, correct me if i am wrong but if the oil seals on the turbos were bad, wouldn't this car be smoking like crazy from the exhaust?
12-05-2016, 03:05 PM | #7 |
Rep 666
Do not add any more oil! Your sensor is most likely bad. Drain the engine, replace the sensor, and refill.
