Headers- are these 5 codes normal?
11-30-2016, 08:47 PM | #1 |
Rep 275
Hello, I've but running my car with AA headers and no tune for... a while now and I just now got a code reader. I wanted to make sure these 5(five) codes were normal. I also ripped out my charcoal filter last time I changed my air filter. That's it for mods
p0420 Catalyst System Efficiency Below Threshold (Bank 1) p2098 Bank 2 Post Catalyst Fuel Trim System Too Lean p2272 Oxygen Sensor Signal Stuck Lean Bank 2 Sensor 2 p2198 O2 Sensor Signal Biased/Stuck Rich (Bank 2 Sensor 1) DTC p0456 Evaporative Emissions System (EVAP system) Last edited by e90dum; 11-30-2016 at 08:47 PM.. Reason: AA |
11-30-2016, 09:40 PM | #2 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.09] |
Everything but evap.
skeetx36.00 |
11-30-2016, 09:44 PM | #3 |
Rep 3,778
Drives: '11 328i '19 M6
Strangely all I see is a couple of P1017 oxygen sensor errors after the C and O readiness monitors set. Probably cuz it's just a simple Innova scanner.
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
11-30-2016, 10:11 PM | #5 |
Rep 3,778
11-30-2016, 10:20 PM | #6 |
Rep 275
Anyone have an evap problem on their e90? I couldn't find any problem areas to check other than the "gas cap" I guess I'll try tightening it lol
11-30-2016, 10:25 PM | #7 |
Mike: Everyone's Pal
2045
Rep 2,972
Drives: F80 M3
I think mine went off when the Eshaft sensor went but I don't remember.
[CENTER]
2021 6.2L Trail Boss, 6" BDS lift, Chevy Performance intake, 35" Nitto Grapplers, 20" Fuel wheels |
12-01-2016, 02:16 PM | #8 |
Rep 2,825
get a tune! what are you doing man? if you choose to invest into headers, you dont just stop there. your Fuel/air mixtures sound like theyre all over the place. you're not getting the most from your headers either.
12-01-2016, 09:01 PM | #9 |
Rep 275
I heard the AA tune is shit(apparently doesn't really change much for the headers? really?) and BPC hasn't responded to me so i guess I'll email em again. I'm gonna put a 3im on first so I don't have to deal with any support later
12-01-2016, 09:10 PM | #10 |
Rep 3,778
BPC is worth it, the only one known to be set up correctly for headers, and the 3IM for that matter.
12-01-2016, 10:09 PM | #11 |
Rep 275
12-01-2016, 10:38 PM | #12 | |
Rep 1,413
Very helpful over the phone... Quoted me about 500 for me to drive there, have it on the dyno as they tune. Or, Like 650? For a 'handheld' device to do it at home. |
12-02-2016, 08:01 AM | #13 | |
Rep 275
So you take your ECU's file with the handheld and email it to em, and they'll send you back a tune for the car. Sounds intuitive |
12-02-2016, 02:00 PM | #14 | |
Rep 1,413
Timely process for the copy to download and the tune to overwrite. Make sure you have a small battery jumper avail. You gotta make sure your cars ECU doesnt 'go to sleep,' per say.... Let us know how it goes!! |
02-06-2017, 03:11 PM | #15 |
Rep 1,710
So after the tune I'm getting a CEL after about 100 miles. Pulled codes and got P0420(bank 1) as logged and a pending P0430(bank 2) along with P0420. is it possible that the sensors may have rattled loose during the break-in period of the headers? I didn't put enough torque on them is what I'm hoping and it's as simple as going back under the car with a O2 wrench. I was careful not to knock them, but one tapped a bit hard so maybe that's what is is and I'm boned. So, how do I ID which header is bank 1 or bank 2?
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
02-06-2017, 04:15 PM | #16 |
Rep 1,598
I don't have five codes with AA Headers and no tune, only two codes show up on mines which are both post cat errors from bank one and bank two.
02-06-2017, 06:48 PM | #18 |
Rep 1,710
What is SAP??? I decided to roll to the exhaust shop to have them check my sensors and they were slightly loose, nothing serious and they tightened them up at no cost to me. Turns it out it's not that, Bob from BPC said will look at the file once I update him on what the results of the 1st tune he sent me. Hopefully it really just is a tuning quirk rather than a problem with hardware.
02-08-2017, 01:29 PM | #20 |
Rep 1,710
02-08-2017, 09:27 PM | #22 |
Rep 1,710
Hmm...is that regulated by the O2 sensors? You have me thinking now because when I installed the headers and drive the car I hear like a slight fluttering noise that isn't like the valve tick.
