E92 335i Side Fender Removal/Install HELP!?
12-01-2016, 02:47 AM | #1 |
Instagram: DHaigh90
Rep 23
Searched everywhere for DIY, you'd think it's straight forward...Offside fender took a bang, replacing with OEM...4 bolts under the hood, 2 on adjusting bracket under side skirt, 1 under thewheel arch/bumper, but the 3 inside the door is were the problem occurs...
Top one of the three inside the door is accessible as bolt head is on the outside (so accessible when door is open), the middle and bottom are screwed in from the inside of the fender, how do I get to these? Screen wash tank is inside blocking access...surely someone had had the same Problem? Thanks |
12-01-2016, 05:38 AM | #2 |
No 55mph
1623
Rep 8,479
I assume you are talking about accessing problem on PS?
If so, just remove the bolt that holds washer tank, pull the tank out (leave everything connected) and you will be able to access the bolts
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-02-2016, 04:28 AM | #3 |
Instagram: DHaigh90
Rep 23
Tags |
diy, e92, side fender |
