WTF car!?
12-05-2016, 06:55 PM | #1 |
Rep 723
WTF car!?
Here are the errors i pulled. Dont know i[IMG][/IMG]f it's the battery, a yelloy battery came on too. That said the battery is 2 years old. Was driving fine, went over a speed bump at 5 in DC and Christmas Lights on dash! ABS, Airbag, you name it.
Thoughts?
2007 335i E92 MT | MFactory LSD | Diff Brace | MHD/Wedge Tuned| BL Coils | Stg2 lpfp BoostConcepts | VRSF DPs | VRSF 7" HD FMIC | DCI | VRSF CP | BMW SSK | Billstein PSS Coilovers | M3 Control Arms | Whiteline Rear SF Inserts | SS brake lines | Z4 35is Rotors | Hawk 5.0 pads | M219s + PSS | PE Mod -SOLD
2016 M4 F82 MT |
12-05-2016, 07:17 PM | #2 |
Apprentice
373
Rep 801
I'd like to point your attention to the 11.62 voltage output. That in itself just seems like a faulty battery.
Try testing your battery at a local autoparts store! |
ritzzzzzwik234.00 |
12-05-2016, 09:17 PM | #3 |
BMWCCA 149159
38
Rep 847
BMWs don't do well with voltage less than 12.0VDC. Other possibility is that the battery cable recall was not done causing these readings. If it has been done sure sounds like a battery headed or gone south....
The bump is what has me thinking that the battery cable to fuse box recall has not been done. Your symptoms are exactly what usually happens. Try this pound on the glove box or right above it and see if most of the errors clear. The cable is located in the back of the fuse box there. Please post what it happens to be so we can all learn from your misfortune.... |
ritzzzzzwik234.00 |
12-05-2016, 11:24 PM | #5 |
Rep 723
I've dropped the car off at the shop. The running voltage was 16, isnt that high? I thought it was supposed to be around 14.
2016 M4 F82 MT |
12-06-2016, 04:33 AM | #6 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Yes that is, I'd go ahead and replace that son bitch and have it coded... How old is it btw?
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
ritzzzzzwik234.00 |
12-06-2016, 11:19 AM | #8 |
Rep 723
Ok so apparently the alternator is cooked. overcharged the battery. so new battery and anternator. FML! There goes my money for LSD.
2016 M4 F82 MT |
12-06-2016, 11:27 AM | #9 | |
Rep 649
Drives: F80
<Long Explanation> As your battery gets older, it looses some of its potency or voltage, the car dosent like this, so to compensate the alternator is told to work harder to help out the battery. If you just drop a new battery in, without telling the computer, it will assume that the new battery still needs help keeping up, and the alternator will fry it, and maybe take itself out as well. </Long Explanation> So if you or a local shop changed your battery recently, I would think that would be the case, if it was a shop you may be able to get them to pay for the new alternator and a new battery, if you did it last, then thats unfortunate and just means time to replace them both out of pocket. |
12-06-2016, 11:33 AM | #10 | ||
Rep 723
2016 M4 F82 MT |
12-06-2016, 11:35 AM | #11 | |
Rep 649
Drives: F80
12-07-2016, 05:54 PM | #12 |
Rep 723
Lazarus is back!
So now if one adds up all the costs of repairs, its more tyan what I originally paid for the car. that said i did buy it at about 1/4th the original price of the car. The BMW yax is real folks. Hopefully this is the end of all the troubles its had this year, with pretty much every single thing having been replaced, besides Engine, Clutch, and Trans (and body ofcourse ). Knock on wood!
2016 M4 F82 MT |
