E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Headlights dirty from the inside
Reply
      12-08-2016, 12:13 PM   #1
jeddo45
Apprentice
Drives: 2007 BMW 335i
Hi all
I had my car fully detailed. Although the headlights and foglights looked better after, they still have buildup from what looks like the inside.
My question in short:
Is there a way that you could actually clean the covers (headlights, foglights) from the inside? Or will this be a nightmare DIY? I have Xenon Adaptive headlights.
The only thing I could find on the forums is people cleaning the outside, so I apologize if this has already been discussed.
      12-08-2016, 12:40 PM   #2
Nicky92
Fastest 335 on Earth
39
Drives: 2008 335i
you have to open them up
bake them remove cover clean and reseal
E92 335i, 6MT- YouWish Single turbo, Precision 6466, Doc Race intake manifold w/port injection, Precision Raceworks coil packs and Stage 3 lpfp, 3.46 geared Mfactory LSD, VRSF 3.5" single exhaust, Toyo R888Rs, Spec Stage 3+ clutch, DSS axles, RTD shifter, Motiv, boost box and flex fuel, WOTBOX, MOTIV tuned...and much more
      12-08-2016, 04:08 PM   #3
jeddo45
Apprentice
Man, this is what I was scared of! I thought the way the headlight was assembled was with clips and thick seals.
Thanks for the info.
      12-08-2016, 08:48 PM   #4
siphor1989
Drives: 2020 m340i xdrive
Be careful cleaning the inside of the lens because unlike the outside, it will scratch extremely easily.
      12-08-2016, 11:02 PM   #5
jeddo45
Apprentice
OK, so what is recommended. I was thinking of a similar procedure for what's done on the outside (high grit sanding and buffing)
Is there another way to do this?
      12-08-2016, 11:04 PM   #6
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
Shouldn't need to sand, just get a brand new microfibre towel and glass cleaner.
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP /
Reply
e90post
