E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Rear wheel rubbing
Reply
      12-10-2016, 09:28 PM   #1
HereComesAnotherBMW
Drives: 2007 320i e90 sedan
Rear wheel rubbing
My ride is lowered 30mm. I just put 19" wheels on. The tyres are 265/30 - too wide i know. The passenger side doesn't rub but the driver side does. The other day was changing the sensor and noticed the spring upper pad had completely busted. I pulled it out and it was all dried up.
I was going to get the fender rolled, but if only one side is rubbing, I'm thinking it could be the now-missing upper pad (part 9 on the attached image).
Could the missing spring pad be causing the spring to collapse too much?
      12-10-2016, 10:47 PM   #2
HereComesAnotherBMW
This is the link
http://www.realoem.com/bmw/enUS/show...diagId=33_1263
      12-11-2016, 12:40 PM   #3
Bluewater328iT
Bluewater328iT's Avatar
Drives: 2011 BMW 328iT
I'd replace upper pads on both sides before rolling the fenders. However, rolling will give you more clearance.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows
      12-11-2016, 01:57 PM   #4
NicksBimmer
Drives: 2010 E92 335i, 2018 F15 35d
How many miles are on your car? I get the same rubbing on only the driver side and have been planning to roll the fenders but maybe I'm having the same problem. I have the stock suspension setup tho on my E92 with only 46K so i hope its still holding up.
      12-11-2016, 06:37 PM   #5
hawkjr1
Retired US Army/Police Officer
hawkjr1's Avatar
30
Drives: F10 M-Sport, E-92
I run the same size on mine and no rub.
318IS-330IC-E90-E92 328i F10 535i M
Reply
e90post
