Anyone use Techron Concentrate Plus Fuel System Cleaner ?
12-10-2016, 10:43 PM | #1 |
Rep 790
I put a bottle of it in my fuel tank recently.
Don't know if it's doing anything but I guess it can't hurt. Anyone else use it? |
12-10-2016, 10:53 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
I use it the tank before every oil change if I can remember to. I honestly can't tell a difference though.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
12-10-2016, 11:00 PM | #3 |
Rep 204
I've tried every so now and then but VTECaddict said, I cant tell the difference, but I heard some good things about Redline and Royal Purple cleaners....
12-10-2016, 11:10 PM | #4 |
Rep 1,051
Techron's been around for a very long time (decades). It used to be that my BMW dealer would put a bottle of it in the gas tank, whenever I would bring my car in for routine maintenance. Then Chevron started to include it in its gas pump gasoline. In 30+ years of driving BMWs, I have never had fuel injector issues, which is why BMW put a bottle of it in before Chrvon gas included it. I still use mostly Chevron gas.
12-10-2016, 11:13 PM | #5 |
Rep 13,128
I might clean your injectors but it won't clean you valves
in a direct injected engine. Because the gas doesn't pass over them. The only thing that will clean the valves is a direct cleaning via the Walnut Blast or hand brushing. |
VTECaddict481.00 |
12-11-2016, 12:20 PM | #7 |
Rep 471
I use top tier gas, usually Shell, but I do quite a bit of stop and go driving, so when I recently starting getting some odd codes about fuel/air mix, I put some in. I am still on that tank, so the jury is still out, but I am hoping it will clean the injectors. The dealer cleaned them a year ago, so I am hoping to avoid that expense, if nothing else.
Chevron gas is not available in NY anywhere around me. Techron is an additive that they use, but even if you are using good gas, it would not hurt to use a couple of bottles once a year or so, unless you do all highway driving.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
12-11-2016, 12:25 PM | #8 |
Car Enthusiast
916
Rep 1,311
Drives: E92 328i 2007 SC
I use the Lucas cleaner, combined with only Shell/Chevron 93. Works fine for me!
E92 328i|6MT|ESS SC VT-1 (G.2)|3 stage|22 RPD SC/Meth tune|AA Headers|Snow Performance Meth Injection|Rotiform KPS|R139|PS4S 275.245.19|M3 front|M3 side skirts|MTEC rear|Akrapovic C tips|Koni Sport (Yellow)|Eibach PS|Hotchkis SB|C high-kick spoiler|C mirror Covers|C trim|LCI tails|M3 Control arms|M3 MS|Black E trim|Black kidney's|Full LED Conv|BMW F30 370/345 BBK|ECS SS|ECS Strut Tower Brace|034 Engine-Trans-Rear Mounts
12-11-2016, 08:51 PM | #9 |
Rep 96
Drives: 2011 BMW E92 335i V. Red/SB
I use a bottle every 3000 miles. Probably doesn't do anything but it can't do any harm, particularly as I use Chevron gas most of the time
12-12-2016, 12:54 AM | #10 |
Rep 424
i use it because i fell for the marketing
Seattlesquash915.50 |
