Who has rebuilt or modified the GM 6L45 6AT Trans?
12-14-2016, 12:09 AM | #1 |
Rep 114
Drives: 2008 E91 ZSP
Before I resume track days in the spring, I want to get rebuilt/reman 6L45 trans along with a trans cooler to replace my 222,000 mile trans. Who has a rebuilt/reman trans and did the shop improve it with a shift kit, and better TQ? I noticed sonnax has a zip kit and line pressure booster kit. Anyone know a transmission shop that installs that stuff during the rebuild? Also, I've read the 6L45 is related to the 6L50. Does the 6L50 fit/function fine?
2008 E91, ARC-8, 255/40/17 NT01, ER sport cooler, TCK camber plates, coil-overs 400# front 700# rear, Koni SA shocks. M3 Subframe bushings, front + rear control arms, tension struts, strut brace. Quaife, Carbotech, Schroth.
12-14-2016, 09:22 AM | #3 |
Rep 114
This is still a daily driver (wife 90% of the time). The 6AT trans rebuild is the last mod for the wagon for street reliability and weekend track days. High mileage and track abuse stacking the deck against original trans. My plan for 2018 is getting an e36 M3 track car.
12-14-2016, 07:12 PM | #5 |
Rep 2,825
12-14-2016, 07:29 PM | #6 | |
Rep 39
GM transmissions actually some of the best you can get, especially their auto's. |
Taskmaster2469.00 E91 M Sport103.00 |
12-14-2016, 10:15 PM | #7 | |
Rep 2,825
ZF trasnmission is in cars like audi, chysler, some new acura's, our BMW's etc. Porsches PDK is ZF design. this is a little list of reported zf transmission failures i got somewhere off the internet BMW - 0 failures Acura - 10 Chrysler = 110 (!) point in case. programming is important, and something you cant trust the americans with. in fact, Im skeptical of almost all american cars, except for some ford models which use a Mazda chassis and engines from their prevous partnership (ford duratec and ecoboost engines are both designed by Mazda) |
12-15-2016, 02:02 AM | #8 | ||
Rep 2,287
12-15-2016, 11:21 AM | #9 |
Rep 2,825
i was literally able to feel my transmission was slowly killing itself before I changed my transmission fluid. it runs so much better now. i feel like the thing with the 8 speed automatic is the shift points are complicated and different from a normal automatic, so you really have to pay attention to your throttle inputs to get the transmission to operate smoothly.
12-15-2016, 06:14 PM | #10 | |
Rep 5,015
I mean, did you comb through the f10 to make sure none of its programming code was maybe possibly done by some American intern on the ZF team? Gasp. The reality is that these are teams of people dedicated to certain objectives with cost restraints. Some people have higher cost allotments and others don't. The ZF trans is good, but it's also seemingly more sensitive to fluid change interval. This would be a negative. |
Taskmaster2469.00 Jonah33554.00 |
12-15-2016, 06:15 PM | #11 | |
Rep 5,015
12-15-2016, 06:29 PM | #12 |
Rep 2,287
Are you actually sure GM transmissions are built in the USA?
I thought this gearbox was built in Strasbourg France. |
12-18-2016, 07:21 PM | #13 |
Rep 406
Drives: S54/N52
Yeap. GM slushbox is built in France but I don't think anyone figured out origin of TCU coding or cracked GM box's TCU (Saw someone mentioned it was encrypted tightly but who knows).
GM Brand name doesn't automatically mean built in America/Coded in America tho. There's been quite a few misinformation slinging around lately.. comb through carefully. |
12-19-2016, 07:42 AM | #14 | |
Rep 1,191
Drives: 2009 BMW 328i Wagon
Also, if you look at the Trifecta (a popular GM tuner) tunes for the ATS, Colorado and Camaro, all of their engine tunes adjust the transmission programming as well. |
12-21-2016, 03:58 PM | #15 |
Rep 114
Anyone use the PCS TCM-2600 controller?
12-22-2016, 12:18 PM | #17 |
Rep 1,076
04-16-2019, 01:22 PM | #18 |
Rep 2,203
Resurrected -
Did anyone locate shops or parts websites to perform a rebuild to the 6l45? I've found a few sites that are able to sell the regular sonar zip kits etc. Not much info and not many shops want to actually touch the trans. It does seem that the Valve body is the weak link of the whole unit. Plastic check balls, plastic switch plates etc.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
04-18-2019, 02:03 PM | #20 | |
Rep 18,796
04-18-2019, 04:15 PM | #21 | |
Rep 7,215
I have no idea how involved that is, but you definitely can't just swap in a used transmission on an automatic without doing a little extra work. |
04-19-2019, 03:39 PM | #22 | |
Rep 5,015
