M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Detailer's Domain brings some life back to this Range Rover - Improper Washing
      12-19-2016, 10:45 AM   #1
Detailers Domain
BimmerPost Supporting Vendor
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
Got a call from a great customer of ours asking us to help him out with his dad's Range Rover. He told us that the car is in bad shape due to improper washing. I said really why don't you fix it yourself. He said no time and it's too far gone. I said you have everything to do it. He said you don't understand he washes it with bleach and various home cleaning goods. I said what! I told him if we do this you will have to teach him the right way to wash his RR, he said I can't promise you anything and this is a gift to him, what he does after he's on his own.
Figured a quick run down on swirls removal and paint correction would help those on this article.
What Is Car Paint Correction?
AKA - swirl mark removal or machine polishing, paintwork correction is the reduction or removal of marks in the top layer of paint to produce a more refined finish.
Paint correction can involves machine polishing of varying grades of cleanser, polish or compound. (can also be done by hand but in todays time and with todays finishing I would recommend machine polishing, preferably via an orbital polisher)
Paint correction requires a high degree of skill and concentration, but done properly, it really can transform the look of a car by dealing with hard water marks, etching caused by bird droppings or bug and tar, swirl marks, scratches and fading or dull paint.
Done professionally, paint correction is entirely safe and will not cause any issues for your paint.
Why Consider Paint Correction?
A vehicle’s paint has to deal with a lot of environmental challenges:
Road grime and grit
Bird muck, fly squash and tree sap
Tar
Water spots
People brushing against the car with their clothing or bags
Poor valeting techniques and/or products
Poor machine or hand polishing techniques
Auto car washes
All of these things can leave the finish of a car looking less than perfect and at worst, dull, faded and covered in light scratches, swirls and other marring. Not only does this detract from your car's appearance but it ultimately reduces its value as well.
For most, paint correction really can make a substantial difference and will completely remove or significantly reduce most marks. Not only this, but the resulting finish will have an amazing gloss, depth of reflection and slickness.
Will swirls and paint issues reappear?
New marks may appear over time (we can't stop future scratches), but with proper care you should be able to prolong them from reappearing.
Paint Defects
This project will:
Remove all light haze swirl marks
Remove any existing buffer trails/holograms
Add an amazing shine and depth of reflection
Restore most faded paint & reduce surface oxidation
Create a stunning smooth/glossy finish
Provide paint protection(3-6 months)
Leave a slick feeling finish which is easier to clean
This project will not:
Remove the deepest swirl marks (circular scratches)
Remove deep etching from bird muck, water, etc.
Remove more than the very lightest of scratches
Restore heavily faded paint or sub-clearcoat issues
Improve the appearance of stone chipping
Full list of products used during the new car process
Exterior
Nanolex Prewash Concentrate
Nanolex Wheel Cleaner and Iron Remover
Stoner's Tarminator
Nanoskin Autoscrub Sponge
Uber Clay Bar
Nanolex Ultra Glass Sealant
Nanolex Glass Cleaner
Meguiar's M101
Meguiar's M205
Nanolex Tire and Trim Restorer
Nanolex Spray Sealant
Interior
Nanolex Interior Cleaner
Nanolex Textile and Leather Sealant
Tools used:
Metro Vac N Blo Car Vac Pro Series PRO-83BA CS
Metro Air Force Blaster 8 hp
Rupes LHR15 MKII
Rupes LHR75E
Meguiar's Microfiber Cutting Disc
Uber Green Foam Pad
Uber All Purpose MF Towels
Uber Classic MF Towels
Uber High Tech Glass Microfiber Towels
Scangrip Multimatch Light
Before shots
Short on the prep shots but some foam shots and work flow shots
Paint Correction
Driver's Side Fender
Before
After
Driver's Side Door
Before
After
50/50 shots
The biggest difference was on the piano black trim
Much much improved this is not done yet, we had to finish it down further.
Final shots
      12-20-2016, 01:38 PM   #2
hshot_rooke
Drives: 2017 BMW M2
Wow. That's awesome. Great job!
Some questions:
I'm assuming paint correction cannot be done indefinitely? As there is only so much you can buff the paint down?
I understand that a coating on the car can swirl. If a coating is put on top of the clear coat and becomes 'swirled', can the coating be removed and reapplied so that your paint and factory clear coat stay perfect indefinitely?
Sorry if I butchered the explanation.
      12-20-2016, 08:15 PM   #3
Detailers Domain
correct. you could ask your detailer to check the paint for you with a paint meter. from there you both can keep a record of how much is left. typically we check paint for customers and tell them how much we can do for them. I stop correcting paint at about 69-71 microns.
If you coat the car and it swirls you can spot polish the areas that are of concern. That being said you can compound or polish off your coating, and eventually into your clear coat /paint.
Tags
detailersdomain, detailing nj, nanolex, range rover
m2
