Temporary OFHG Fix?
01-05-2017, 09:33 PM | #1 |
Rep 49
Drives: 2007 328xi
Temporary OFHG Fix?
So just found out my oil filter housing gasket is leaking a lot more then I originally thought after changing the oil less then 1000 miles ago. I would hate to pull the housing off and waste all that new oil plus its freezing out.
Anyone temporarily fix their OFHG leak with silicone or some type of high temp sealant? |
01-05-2017, 09:37 PM | #2 | |
Rep 2,825
01-05-2017, 09:50 PM | #4 |
Rep 49
Drives: 2007 328xi
01-05-2017, 11:50 PM | #5 |
Rep 5,015
If your car is cold and you crack the oil filter to let air in the oil will drain into the block. The crossover is next to nothing.
You would have to seal around the entire unit to stop the leak externally and since there are places that you cannot access I believe you'll just push the leak in another direction. |
CW14.00 |
01-06-2017, 10:16 AM | #6 |
Rep 947
Not much oil is lost when you do the housing gasket. Just replace it. If oil drips from the housing gasket onto your belt, you risk the belt potentially getting sucked into the motor which will require oil pan and valve cover removal at the very least.
01-06-2017, 12:31 PM | #7 |
Rep 5
x2 on not much oil being lost. I would lay out rags under the housing to prevent the fluid from hitting the belt. Crack open the filter lid first so a lot of the oil goes back down into the motor. You won't lose more than you burn in an oil change interval anyway.
The biggest loss is coolant which is still marginal. I just added a half gallon of distilled water and bled the system. I will change out the coolant when i do the water pump and thermo. I'm at 105k miles. |
01-06-2017, 03:52 PM | #9 |
Rep 49
Drives: 2007 328xi
So the "cross contamination" between oil and coolant isn't a big issue with this job?
01-06-2017, 08:34 PM | #11 |
Rep 775
01-06-2017, 09:00 PM | #12 | |
Rep 5,015
Just make sure you open up the oil filter compartment first, let it drain, then re-seal and remove the whole unit. 90% of the spillage that occurred when I did it was coolant that's bc the motor was warm. Oh wellz |
CW14.00 |
01-07-2017, 10:53 AM | #13 | |
Rep 2,109
Mercedes uses very similar design I know from a friends car, and its gasket was leaking too. |
02-01-2017, 03:45 PM | #14 |
Rep 49
Drives: 2007 328xi
Just wanted to update and say I did the job it took about 30mins and there was no crossover and very minimal coolant loss. Thanks for the help!
02-04-2017, 08:49 AM | #16 |
Rep 2,825
02-04-2017, 09:21 AM | #17 |
Rep 2,793
02-06-2017, 02:46 PM | #18 |
Rep 922
Nice to see the resolution. I replaced my leaky OFHG a few weeks ago when the oil dripping onto the belt created a horrible "chirping" noise. Forget all the sealant/glue/whatever methods, replacing the gasket is really not so bad.
2006 330i 6MT Jet Black / Black
