M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 513M (18" M4 wheels) for track work??
      01-15-2017, 02:04 AM   #1
pruettfan
Drives: 2017 M2, LBB, DCT, Exec
I am beginning to do some autocross and HPDE days so I have been considering going with a dedicated wheel and tire setup. I am considering buying a set of 513M wheels with tires that were taken off an new M4. I am guessing they will fit the M2 fine because of the common components and they are a bit lighter than the 19" setup so I am thinking they would be a good track option.
Any thoughts ??
Thanks
      01-18-2017, 03:32 PM   #2
M2OG
Drives: a car
I've been in the same mindset for months. When it's time I'm likely to retire my stock wheels and switch to these. I like taller sidewall tires
      01-19-2017, 01:52 AM   #3
marcusfva
Italy
70
Drives: M2'17 DCT
The 513M fit perfectly the M2.
http://f87.bimmerpost.com/forums/sho...&postcount=117
      01-23-2017, 11:32 PM   #4
TheKosherStogie
TheKosherStogie's Avatar
Drives: 08 M3 DCT AW/Red
Running them for track wheels as well
      01-25-2017, 01:37 AM   #5
_pancho_
_pancho_'s Avatar
Sweden
16
Drives: modified F87 M2 Man -17
Will a set of 265/35-18 R888 fit the 9 inch wide front wheels?
regards Tobias
      01-25-2017, 08:36 AM   #6
Hossel19
Drives: M2
It is not ideal but they fit.
According to tirerack the rim width range is 9-10.5 inch
      01-27-2017, 01:40 AM   #7
_pancho_
_pancho_'s Avatar
Sweden
16
Ok thank you,
I have four of these tires in that dimension, and wonder if I could use them for the M4 wheels...
      01-27-2017, 11:48 PM   #8
TheKosherStogie
Posted mine here
http://f87.bimmerpost.com/forums/sho...1289598&page=2
m2
