oil leak help plz
02-16-2017, 01:19 PM | #1 |
Rep 606
oil leak help plz
hey guys, I'm trying to fix these oil leaks. I changed the filler cap because it seems like that's where alot of oil is leaking from but I was wondering what the cable thing is that is also leaking oil in the second picture is and is there like a gasket or something that can be replaced on it or the whole thing.
02-16-2017, 03:07 PM | #2 |
Rep 149
It looks like your valvetronic motor gasket is leaking as well as eccentric shaft sensor. Thier is a good chance ur valve cover is warped or cracked as well. Your going to have to replace all mentioned gaskets at a minimum. I just ordered a valve cover just for peace of mind due to them being plastic they warp and crack
02-16-2017, 03:12 PM | #4 |
Rep 606
the valve cover gasket seems like it was replaced because there's a bunch of that orange stuff, I think it's called rtv, visible around the valve cover meeting the engine.
02-16-2017, 05:21 PM | #6 |
Rep 149
If thier is oil visible leaking where the gasket is my bet is the valve cover is warped or cracked. A lot of indy mechanics where i live say to replace the whole cover otherwise the gasket for the cover typically starts leaking every 6 months. If you have the patience to continually replace the gasket for the cover than just keep buying gaskets unless its cracked. The bolts also tend to snap ive been told due to them being over torqued from factory
02-16-2017, 06:14 PM | #7 |
Rep 606
yea I agree, I don't know if they replaced both the gasket and valve cover or both. but it looks like it was leaking around the filler cap. so I replaced the cap. guess I'll have to replace the sensor. I'll clean it up and see if the valve cover is also leaking. thanks guys
02-17-2017, 11:08 AM | #8 |
Rep 947
I don't know how one can tell a valve cover is warped by looking at those photos. The areas that can become warped and cause sealing issues are not even pictured....
I wouldn't immediately suspect oil is leaking from the fill port. Techs can get careless and spill oil there. Clean the area and look for fresh oil after a couple drives. |
Turbo_power4ever93.00 |
02-17-2017, 11:22 AM | #9 | |
Rep 149
02-17-2017, 11:38 AM | #10 | ||
Rep 947
Also ABS/other thermoplastics plastics have a pretty high melting point and even the temperature at which they can deform is quite high. Higher than what this motor reaches (at least where the cover meets the head surfaces). It's when there are other underlying issues with cooling that the valve cover can warp. Last edited by matteblue3er; 02-17-2017 at 11:51 AM.. |
02-17-2017, 12:01 PM | #11 |
Rep 149
I was basing it might be warped off a personal opinion. More of a make sure its not warped or cracked before just putting a new gasket in. It does happen its definitely a design flaw with these valve covers.
02-18-2017, 09:57 PM | #15 |
Rep 149
That doesnt look good to me maybe this other guy can chime in more since he is a mechanic
02-20-2017, 09:46 AM | #16 |
Rep 947
Might be a sign of rust somewhere in the system but I can't think of any components in any N5x system that would rust and cause that much of a color change. It may also be the result of mixing different types or colors of coolant
02-20-2017, 11:29 AM | #17 | |
Rep 606
02-20-2017, 12:01 PM | #18 |
Rep 2,109
02-20-2017, 12:02 PM | #19 | |
Rep 2,109
Also as someone up already pointed your valvetronic motor seal is also leaking. You should replace all three when doing a valve cover gasket replacement: valve cover gastet, eccentric shaft connector gasket, valvetronic motor seal gasket. If you buy a new valve cover, all those come with the new valve cover. |
