E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Europe (Continental) > 330D Cabrio ERRORCodes - Please any help on what they mean?
Reply
      02-19-2017, 08:35 AM   #1
ryk
United Kingdom
Drives: 330D Convertible
Good day all,
I am back with the analysis from Carly. Any feedback on what the significance of the listed faults would be appreciated. Recently had the battery replaced with a BMW matching one and re-coded by the BMW authorised garage.
Used Carly to code to allow the hood to be opened when moving at slow speeds.
Replaced door courtesy lights with laser courtesy lights.
Otherwise no other changes since last service.
iPhone Fault Report - Carly for BMW - 30 - 2017.02.09.2158 FV
ID1: (I removed this identifier info)
ID2: (I removed this identifier info)
INFO: (I removed this identifier info)
2017-02-18 17:41:15
BASE: E93
BUILD-YEAR: 2011
MODEL: 3 Cabriolet (E93) M3 alle/all (51)
ADDITIONAL OBD: OFF
FAULTS: 12
ECUs: 23
BATTERY: 14.3V
DEPTH: Normal communication
SPEED: slow
CONNECT: Fast Connection
VERSION: 10.2
DEVICE: >Iphone< >iOS<
WIFI: >V-LINK v00<
ELM: ><
COM+: >YES<
0. Motor Control:
Engine / Motor:
- Fault: Swirl flap, plausibility: mechanically defective
- Code: 004E0F
- Fault: Battery Power Management
- Code: 004A66
- Fault: Motorabstellzeitermittlung
- Code: 004DFB
1. ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC:
- Fault: unknown failure
- Code: 005DEC
2. Airbag:
Advanced Crash and Safety Management (ACSM):
- ECU OK, no fault code
Airbag B-pillar left/ B-Saeule links:
- ECU not present/no answer
Airbag B-pillar right/ B-Saeule rechts:
3. Transmission Control:
Transmission / Getriebe GS 19:
Transmission / Getriebesteuerung:
Gear switch / Gangschalter:
4. Instrumentation:
Instrument cluster / Kombiinstrument:
- Fault: Shutdown
- Code: 00A559
Central info display / Zentrales Display:
5. Light/Rain Control:
High-beam / Fernlichtassistent:
6. Heating / AC:
Air conditioning / Klimaanlage:
7. Immobilizer System:
CAS:
- Fault: ACK error before KL15 Off Request
- Code: 00A127
8. Park distance control / PDC:
Park Distance Control / PDC:
9. Cruise Control:
Active cruise control / Aktive Geschwindigkeitsregelung:
10. Sunroof / Roof:
Sunroof / Schiebedach:
Roof / Dach:
11. Audio / Navigation / Communication:
Phone / Telefon:
- Fault: Ring break diagnosis error
- Code: 00D690
Tuner Antenna / Antenne:
Hybrid Radio USA:
Digital Satellite-Tuner USA:
Navigation:
CD-Changer / Wechsler:
Audio-System:
Video:
DAB:
12. Seats:
Seats / Sitze:
Seats / Sitze:
13. Systems:
Junction Box Passenger / Beifahrer:
Fuel pump / Kraftstoffpumpe:
Tire pressure control / Reifendruck Kontrolle:
Passive Go System:
Car Communication Computer CCC:
MASK:
- Fault: :unknown failure
- Code: 00E1CD
Car Communication:
14. Anti-theft alarm system:
Interior protection / Innenraumschutz:
Theft alarm / Diebstahl Warnanlage:
15. Chassis:
Air suspension / Luftfederung:
16. Body:
Automatisches Front Steering:
Trailer / Anhaenger:
Fussraummodul /FRM:
- Fault: Hall-sensor-driver s door is defective FH
- Code: 009CC5
Dynamic manager / Dynamik-Manager:
17. Motor Control:
Roof / Verdeck:
- Fault: :Exceeding the speed
- Code: 00A6A4
- Fault: :Relay 5th disc from
- Code: 00A6A1
Steering /Lenkung:
Flexible Bus-Interface / Schnittstelle:
- Fault: :Ring break diagnosis error
- Code: 00E150
Central Control / Zentrale Bedieneinheit:
      09-22-2018, 08:09 PM   #2
BMW FQ
Drives: E60 N52B30
Originally Posted by ryk View Post
0. Motor Control:
Engine / Motor:
- Code: 004E0F
In the days of the e46 the swirl flap was often faulty, broke and make his way into the engine and make a critical damage. Dont know if at e90 times still got this problem but you should take a look there
- Code: 004A66
Every error what have to do with a change of a batt i would do nothing and just clear the errors and check if and what come
- Code: 004DFB
This is an error which may have caused because of a failure of the throttle body. It can't close perfect so when you turn the engine off it is not so smoth as it could be.
- Code: 005DEC
I'm not sure here what this error means.. Could have something to do with the xDrive or VTG(dont know the english name) from the Turbo.. May take a second look
4. Instrumentation:
- Fault: Shutdown
- Code: 00A559
Again an Battery error. Clean and check again
CAS:
- Code: 00A127
Didnt find something here, too..
Phone / Telefon:
- Code: 00D690
Ring break diagnosis error happen when a control unit from the Most System have a failure. With Ista you should be able to make a diagnosis and check which one generate this
MASK:
- Code: 00E1CD
unknown error. Could be anything..
Fussraummodul /FRM:
- Code: 009CC5
If your windows works ignore. The Hall-sensor knows when the window is complete up or down
17. Motor Control:
Roof / Verdeck:
- Code: 00A6A4
- Code: 00A6A1
Do you have any failure with your roof?
- Code: 00E150
this was the same as in the Phone categorie..
In general i would first delete all the error because often they happened just once and additional the iCarly app doesnt show when it happened the first, the last time and how often so it would be just in indication, but i hope you have a reference at some of them and how to handle it.
Reply
e90post
