M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 2017 Model M2 - Looking to disconnect Center Speaker
      03-11-2017, 05:36 AM   #1
mjsaville
United Kingdom
101
Drives: M2 LLB - Arrived 4th Mar 2017
Morning All,
I've read in many posts the M2 sound system benefits from the centre speaker being disconnected but I can't seem to locate it.
I don't have the Harman Kardon upgrade just the Hi-Fi option, when I look at the dashboard the only plastic trim I can see is the 10 - 12 inch by 2 inch air vent very close the windscreen. I can't imagine the speaker being under it as its very narrow.
I may be missing something, but it looks like the hi-fi option does not have a center speaker - Can anyone confirm / deny.
thanks in advance....
MJ
      03-11-2017, 09:22 AM   #2
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Originally Posted by mjsaville View Post
Morning All,
MJ
I'm fairly certain there is still a centre speaker.
Here is a link to disconnecting it, but in short, here is what to do -
"It's quite simple, you would use a plastic trim tool to pry up the grill that covers the speakers. You will then see the speaker screws and simply unscrew them on the larger 4 inch speaker and you will see the wiring harness. Simply disconnect that harness from the larger speaker coming from the amp and that's it. The tweeter runs from the 4 inch speaker, so no power to 4 inch, no need to disconnect tweeter. 5 minute job at most."
http://www.2addicts.com/forums/showthread.php?t=1287550
Also see this on real oem- centre speaker is there.
http://www.realoem.com/bmw/enUS/show...diagId=65_2311
      03-11-2017, 12:00 PM   #3
mjsaville
United Kingdom
101
Thanks for the info, I'm off to have another look see tomorrow. I'll report back shortly.
      03-11-2017, 09:07 PM   #4
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
I've disconnected mine, i have the HK system though, you can't miss the speaker grille if your car has a centre speaker, it is directly behind the idrive screen.
      03-11-2017, 09:45 PM   #5
Ex-MINI
BMW Newb
Ex-MINI's Avatar
Drives: 2016 LBB M2 DCT
Did it make a huge difference? Debating whether to do this as well
      03-11-2017, 10:10 PM   #6
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
I think it has made a difference, sound seperation does appear better but i could not notice a huge change like some have said they've noticed. I'm no audiophile though.
For a free and relatively quick mod I'd definitely recommend you give it a go though, the only thing i found difficult was removing the blue plug from the speaker, took me a while. Lol
Ex-MINI582.00
      03-12-2017, 12:44 PM   #7
mjsaville
United Kingdom
101
Okay, I've checked the dashboard there is no center grill behind the console screen. The dashboard is entirely in one piece. My car was manufactured in Feb 2017, and BMW must have removed it from car's which only have Hi-Fi option as standard. I'll add a couple of pics when I get a chance.
So, I guess this is an advantage as now I don't need to worry about disconnecting the center speaker.
MJ
      03-13-2017, 12:11 PM   #8
jhs1210
Drives: 2017 BMW M2 LBB 6MT
I've disconnected mine, and to my ears there is definitely an improvement. I am going to upgrade the front and rear speakers to Focal, and change out the amp. After evaluating those upgrades, I will see if indeed a subwoofer will be needed.
      03-14-2017, 04:04 PM   #9
D CHOI
D CHOI's Avatar
581
Drives: 2017 BMW M2
I haven't heard the sound system in the M2 yet but I was planning on getting a good 12in sub if the bass doesn't hit hard enough. People say the sound system is pretty good but I need to hear it on my own to judge.
      03-15-2017, 02:01 PM   #10
jtfields
Drives: M2, X2 M35i, X6,328i,230i
I was pleasantly surprised. Doesn't sound too bad, at least compared to my other BMWs (X6 with upgraded sound system and 328i with standard sound system) which leave a lot to be desired.
D CHOI581.00
      03-21-2017, 07:02 PM   #11
mjsaville
United Kingdom
101
I've just taken the grill off one of the back shelf speakers, as I have the Hi-Fi option there are no tweeters. I'd planned to fit JL Audio C2-400x coaxes, so now I'm thinking I need a set of tweeters. Can someone recommend?
Thanks
MJ
      03-21-2017, 07:54 PM   #12
jhs1210
Thanks
MJ
I would recommend just putting the JL coax (or other coax that fit). Putting in components would require fitting in the crossovers in that tiny space.
Maybe someone who has installed components in the rear deck can recommend a specific model.
      03-24-2017, 09:56 AM   #13
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Drives: BMW 2017 M2 07/16 Build
BMW has pushed out a couple Software updates I have a 2017 M2 and the HK sounds system sounds great but. Im on the latest Ilevel. 3.61.1
3.61 update there was a amp update which fixed a bunch of audio issues
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey
2004 E46 M3 White
END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci
      03-27-2017, 07:08 AM   #14
Prodigy.
Prodigy.'s Avatar
Australia
698
Drives: ///M2
Do you know if this update is applicable for a 2016 model with idrive 4 and also if it is possible to see what software version you are running via the idrive?
      03-27-2017, 07:10 AM   #15
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
I'm running Id5 so not sure with ID4 but it's worth a shot having the dealer update the software.
Current
2004 E46 M3 White
Prodigy.697.50
      03-27-2017, 02:31 PM   #16
japanaltaf
Drives: 2019 AW X3 M40i
Did you have audio issues that were resolved by the update? Did you notice an improvement in sound after the update? My 2017 M2 was built 9/16 and the HK itself sounds pretty good to me but I am having a super annoying staticky call issue with CarPlay
Thanks for the info!
      03-27-2017, 03:01 PM   #17
Aust350z
Aust350z's Avatar
Australia
243
Drives: F87 M2
My 1/17 build also sounds pretty good too. Much, much improved over the '16 I test drive where the audio quality was lacking.
      03-31-2017, 02:48 PM   #18
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Yes after the update all the car play issue 90% were fixed it can delay now and then but not like before
Current
2004 E46 M3 White
m2
