04-11-2017, 07:24 AM | #1 |
Rep 1,184
Square cut vs slant exhaust tips
Hey what is your guys preference, and does anyone have pictures of slant tips?
Personally I like the square cut look, but recently I found a tip that meets all my criteria except that it's a slant cut. |
04-11-2017, 12:22 PM | #2 | |
Rep 2,375
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
OldCrow7xx72.50 |
04-11-2017, 07:44 PM | #3 | |
Rep 1,184
Thanks for the input. I can't see the image though. Also I'm glad that I measured my tips. I wanted to go one size bigger and I thought I read the Mperformance tips were 90mm somewhere. They are 80mm. It took me forever to find a 2.5" to 4" tip. Good thing I checked. 4" would be too big imo. I guess i'm looking for 3.5" (89 MM) |
04-11-2017, 09:54 PM | #4 | |
Rep 350
04-12-2017, 08:26 AM | #5 | |
Rep 1,184
BMS has a 3.5" tip, bit it says not for use with mperformance exhaust. I'm not much of an eBay or AliExpress guy, but I might say eff be it and try one of those stainless tips. If it looks good and fits great, if not it won't be super expensive and eBay seems to have a good return policy. Try "BMW exhaust tip" in the eBay search and start scrolling. |
SerenVoX147.00 |
04-12-2017, 11:53 AM | #6 | |
Rep 2,375
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
04-12-2017, 06:51 PM | #8 |
Rep 1,184
Didn't like how the BMS ones weren't sharp edged if that makes sense. They fit perfectly in the M performance diffusion. Only tips I've seen noticeably larger are the Meisterschaft ones.
Yeah I have the same taste. I really like the mperformance, I just wish that they were larger. I like the sharp edge, but also like the dual wall. These are the two I am considering 2.5" Inlet / 3.5" Outlet Chrome Stainless Steel Adjustable Exhaust Muffler Tip https://www.amazon.com/dp/B01LWQ9HVM/ref=cm_sw_r_cp_apa_WWR7yb3D7SS0Y (I would prob tap these and use a set screw) Fedar 2.5" Inlet 3.5" Outlet 8" Long Dual Wall Slant Angle Cut Exhaust Tailpipe Tip https://www.amazon.com/dp/B01IU7ET9C/ref=cm_sw_r_cp_apa_.ZR7ybFHRFXAV (not sure if these would be too long, or if I could just slide them further over exhaust pipe mperformance are around 6") |
04-15-2017, 12:58 PM | #9 |
Rep 1,184
[QUOTE=jmwilson125;21556094]Didn't like how the BMS ones weren't sharp edged if that makes sense. They fit perfectly in the M performance diffusion. Only tips I've seen noticeably larger are the Meisterschaft ones.
Yeah I have the same taste. I really like the mperformance, I just wish that they were larger. I like the sharp edge, but also like the dual wall. These are the two I am considering 2.5" Inlet / 3.5" Outlet Chrome Stainless Steel Adjustable Exhaust Muffler Tip https://www.amazon.com/dp/B01LWQ9HVM/ref=cm_sw_r_cp_apa_WWR7yb3D7SS0Y Ended up ordering these. I'll see how they took and post pictures once I receive. |
04-25-2017, 09:10 AM | #10 |
Rep 1,184
[QUOTE=jmwilson125;21553352]I pulled a caliper on the exhaust outlet and got an outside diameter of 2 3/8" which is about 61 mm. I would think that a 2.5" to 3.5" clamp on or weld on would fit. I think some metric ones come in 63 mm inlet.
*Correction* inlet is not 2 1/2", the pipe flares out which I did not see untill I removed my tip. Looked close to 2 5/8". Looks like I'm shipping the 2.5" to 3.5" back. |
04-25-2017, 05:04 PM | #12 | |
Rep 1,184
I should have specified mpe is 2 5/8,. I have not found a tip that fits and I have have given up looking for now ☹️. The 2.5" tips I do have now look sweet though. I'll have to send them back though. |
04-26-2017, 09:36 AM | #13 |
Rep 2,067
I went with the BMS 3.5" slant cut for my M235xi ragtop.
The OEM 3"ers came off fairly easily and these slipped in perfectly.
2019 X2
04-27-2017, 06:57 PM | #15 |
Rep 1,184
04-27-2017, 07:22 PM | #16 | |
Rep 386
This are weld on only tips; any muffler shop shouldn't charge your more than $100 to weld them onto your stock muffler *I've had it over a year, and i do not see any bubbling or burning of the diffuser nor paint with it being flushed. |
05-13-2017, 11:15 AM | #17 |
Rep 51
Here's mine with the blue titanium burgertuning angled tips!
OldCrow7xx72.50 |
06-06-2017, 12:59 PM | #19 |
msej449
514
Rep 717
Drives: M235i Convertible +LSD 2016
If you're dissatisfied with your OE tailpipes, you might consider having them sandblasted and powdercoated. I did this with mine because of corrosion and I thought they needed to go gloss. Here they are from the sandblaster/powdercoat shop:
and re-fitted: It's not until you get them coated that you realise how thin the OE paint is by comparison, and note the powdercoat is inside as well as outside, unlike the OE. I had considered trying to do them in the body colour but we agreed it would be hard to exactly colour-match. And I did think that I might do them in something outrageous like red, to match all the red on the back of the car, but in the end I went for gloss black.
2016 M235i Convertible Estoril Blue & Oyster
2023 Peugeot e-208 GT (electric) |
06-06-2017, 01:25 PM | #20 | |
Rep 1,184
