What is the peak speed for the best MPG?
04-11-2017, 10:57 PM | #1 |
Rep 780
At what speed does the MPG begin to drop on the freeway? I would like to know for 335i's because i have one but if anyone knows for a different model please share!
04-11-2017, 11:00 PM | #2 |
Rep 7,215
65 seems to be peak for my 330i - that said,it doesn't really seem to make much difference if I'm going 55 or 80, on long highway runs it still averages about 33mpg.
Since all E9x's are basically 3.0 liters (in the US anyway) and have the same areodynamics, I wouldn't expect it to vary much. The primary difference will be gearing and AT vs MT. The 330i mt for example has relatively long gears compared to other models. Last edited by hassmaschine; 04-12-2017 at 08:22 AM.. |
04-12-2017, 12:02 AM | #3 |
Rep 380
What hass said. I just will add that IMHO it's around 50mph. I read an extensive article where they compared different setups, engines, transmissions and surprisingly all of them showed better efficiency at around 50mph. Final gear ratio and aerodynamics matter of course, but for max efficiency slower 50 beats real life 65mph
P.S. That been said - this is purely theoretical question as in real life you won't be able to maintain 50, even in right lane - you'll get honked and screamed by every minute - it's just not worth it lol |
04-12-2017, 12:12 AM | #4 |
Rep 328
The slowest you can go in the highest gear is what has been discussed before, the sweet spot is from 40 to 60 for most cars on the road, with trucks being closer to 40 and more aerodynamic cars being closer to 60. Air resistance is the factor, there is an interesting video from Engineering Explained's Jason Fenske that explains it mathematically:
Gizm0427.50 |
04-12-2017, 12:19 AM | #5 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
95
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
Achappell867.50 |
04-12-2017, 05:00 AM | #6 |
Rep 937
I turn off the car after 120. Seems to work great but then I need to turn it back on when I get down to 60
Achappell867.50 Drifter2090912.50 |
04-12-2017, 07:00 AM | #7 |
Rep 952
For most vehicles it is usually the slowest speed in the highest gear. For the e90, this would be 50-60 when the auto trans kicks into 6th gear and you cruise along in 6th.
Aerodynamic force is the primary negative force against the car and this force goes increases exponentially with speed. (v^2). So going twice as fast results in way more than twice as much resisting force. You can really only achieve this ultra efficient mode off the interstates. You'll be an accident risk trying to drive 50-60 on most interstates. But the underlying formula still holds true, slower speeds will yield better fuel economy.
bone stock
04-12-2017, 07:43 AM | #8 |
Rep 3,190
Well, seeing as I actually have a 335. I notice a massive drop in mpg once I cross 75mph. At 65 mph I get 30mpg, 70mph 28-29mpg, 75mph 23mpg, 80-90mph 20-21 mpg. Now every car will be different as aero will actually play a roll at these speeds.
04-12-2017, 08:27 AM | #9 |
Rep 1,060
On my 335 is about 55mph.
JB4 Tune, MHD backend flash, E85
VRSF 7" Intercooler, BMS OCC VRSF CP & TIAL 50mm BOV, BMP PI DocRace 6266 single turbo. |
04-12-2017, 09:08 AM | #10 |
Rep 6,968
Drives: 2007 Black/Black 335i e90
I have got 30.5 miles per hour with my n54 going mostly 80mph on a hwy trip of 500 miles. maybe 60 of those miles were at 60mph because I was in a 55 zone.
04-12-2017, 09:52 AM | #11 |
Rep 2,554
I saw a report once where it said at 50 MPH your engine only needs to produce like 7-14 HP to keep you going. But the real answer is it varies for every car. Whatever the speed in which your car shifts into 6th gear is. So if your car shifts into 6th at 46 mph like mine, then somewhere around there is the best. I've seen 36-39 mpg with my car doing 45 mph for 15 miles before. Highway speeds add more drag and require more power.
04-12-2017, 11:07 AM | #12 | |
Curmudgeon and Pedant
692
Rep 3,489
My 335d doesn't get into 6th until 48mph; anything less than that gives lower mpg. Note that 48 mph (in my 335d) is 1200 rpm, which is the minimum rpm that maximum torque is available - it's similar for 335i. You want max torque as that's essentially where the engine is able to supply enough to maintain speed. Wind (air resistance) makes a lot of difference. Driving cross state (WA), the wind is almost always from the west. I usually get a couple more mpg going east with the wind than east into it. Hills don't make as much overall difference, as you regain the energy (mpg) going down the other side of the pass what you lose going up. For instance, in crossing WA state from Seattle to Pullman, max mpg (going east) is usually at Crab Creek (near Othello): the low spot of the overall trip (yeah, the Columbia River is actually lower, but you have to go back up after crossing it ...) |
04-12-2017, 01:30 PM | #13 | |
Rep 2,825
going 80 doesnt seem to be any less efficient then 60. I believe it is because theres more torque at 2.5k rpm which helps the engine hold speed more easily |
04-12-2017, 04:02 PM | #14 | ||
Rep 2,554
04-12-2017, 04:30 PM | #15 |
Rep 2,343
On a flat road at a constant 50 I can see 40mpgs from my 335i with 7th gear (dct)
Still done 30mpg with a great deal of time spent at 100 though. You have to factor what your time is worth |
04-12-2017, 05:28 PM | #16 |
Is it the shoes!?
3885
Rep 5,112
04-12-2017, 06:34 PM | #17 | |
692
Rep 3,489
04-12-2017, 07:15 PM | #18 | |
Rep 137
FURTHER: what is your experience mpg driving at different speeds? Give us material we can discuss. Thanks, Last edited by 335udm; 04-12-2017 at 07:37 PM.. |
04-13-2017, 11:32 AM | #19 | |
Rep 780
2) I have not cared enough, thats why im asking the forum smart one. |
04-13-2017, 11:33 AM | #20 |
Rep 780
04-13-2017, 11:37 AM | #21 |
Rep 780
Yeah i hope not at least lol i think im churning around 2.75k rpm though at 80mph.
