      04-12-2017, 01:11 PM   #1
TXSTYLE
"Salud"
TXSTYLE's Avatar
Drives: F01 & F15 / Mineral White
Yes... I have a thing for Big Bold Luxury SUV's! I'm from TEXAS. But I'm tired of the plethora of Escalades everywhere. I remember seeing the Lincoln concept a couple years ago and to my amazement and joy, the upcoming production model looks identical, save the gullwing doors (which we all knew that ain't happening!)
The current Navigator is hideous and not even in the same league as the big Caddy. This however, is coming out swinging for the fences and looks like it may reach the parking lot.
I absolutely love the front end and side profile of this SUV! And the interior is as close to a quiet lounge as it gets! And the fact that it is powered by a V6 that will produce 450hp, yeah, I'm interested. The only thing is that the wifey doesn't like parking and navigating with big SUV's But I definitely will go and test it out...
Quieting the interior of the new Navigator employs several technologies. First up are laminated windows to keep the noise out, followed by a noise-canceling system to catch what’s left. The heating and cooling ducts have been tuned to minimize noise, as have the tires. Anything that gets through all that can be drowned out by the 20-speaker Revel Ultima stereo, but you won’t have to crank it up much to get the job done.
2018 Lincoln Navigator front three quarter
You’ll have a lot of options for what comes out of those speakers. In addition to the usual radio sources, the Navigator also accepts inputs from your phone, either via the USB or Bluetooth, and supports Android Auto and Apple CarPlay. Second-row passengers even get their own audio controls. They can also be hooked up with an optional entertainment system, which mounts 10.0-inch screens to the backs of the front seats. The screens can be fed from SD, HDMI, and quick-charging 2.5-amp USB ports, or wirelessly from your Android phone, and can stream different content on each screen. If you’ve got Slingbox at home, you can even watch live TV. The Navigator also comes with an onboard Wi-Fi hot spot if you’d prefer to be online.
Whatever your entertainment, you’ll enjoy it from the comfort of French-stitched leather seats in all rows. Up front, Lincoln’s heated and cooled 30-way power seats with memory settings are standard for both occupants and feature massage functions, and the second row can be had as a three-passenger bench or two captain’s chairs. Either way, the second row gets its own climate controls, and the seats can tilt and slide even with a baby seat installed for third-row access. Back there, the only option is a 60/40 split bench with three seats, but the two sides power recline independently (Lincoln claims best-in-class second- and third-row legroom). All three rows have two USB ports and one 12-volt port (plus a fourth in the cargo area), and there’s a 110-volt outlet in the second row. A panoramic sunroof lets everyone feel the sun on their face.
Behind the third row, the cargo floorboard can also act as a shelf or a vertical partition to keep your things in place. The cargo area can be accessed by opening the full hatch or just the rear glass.
Wherever you plan on sitting, you’ll be greeted by Lincoln’s signature Embrace light show. As you approach, the Lincoln badge in the grille lights up, the LED running lights and taillights activate in sequence, the welcome mat puddle lamp illuminates the ground below the front doors, lights behind the door handles come on, the interior lights go on in sequence, and the power running boards (except on the base model) deploy. Even the seat belt buckles have LEDs embedded in them.
Once in, Lincoln has made sure everything you touch feels expensive. In addition to the seats, the steering wheel and even the grab handles are all wrapped in stitched leather. The push-button shifter moves below the infotainment touchscreen and is designed to look like the keys of a Steinway piano and finished in high-gloss ebony.
As you settle in and stash your bag or purse in the dedicated storage space below the floating center console and your phone in the wireless charging tray, the Navigator will recognize which key fob you’re carrying and adjust up to 80 vehicle settings, everything from radio presets to mirrors, pedals, and cabin temperature.
Fire up the engine, and you have six driving modes to choose from, each of which reconfigures the 12.0-inch all-digital dash cluster. (You can reconfigure it as you like, too.) Normal is the default, Conserve means eco, and Excite means sport. Slippery handles rain, ice, and dirt roads, and Deep Conditions handles deep snow, sand, and mud. Slow Climb locks the rear differential for ascending steep hills off-road. The computer recognizes when a trailer’s been attached and automatically goes into a towing mode. All modes make changes to the throttle mapping, shift points, CCD active dampers, and stability control.
On the road, a standard 360-degree camera system and parking sensors will assist with tight maneuvers, and an optional trailer assist system will help you back a trailer from a controller on the center console. Adaptive cruise control will take some of the load off during long road trips and bad commutes.
The sole engine option is Lincoln’s 3.5-liter twin-turbo V-6, now with an estimated 450 horsepower, 500 lb-ft of torque, and auto stop/start technology. It drives a 10-speed automatic gearbox and an all-wheel-drive system with an electronically locking rear differential. Lincoln promises class-leading performance, towing, and fuel efficiency out of the 2018 Navigator, which is 200 pounds lighter than its predecessor. Lincoln no doubt considers its primary competition to be the Cadillac Escalade, so the Navigator would need to hit 60 mph in less than 5.9 seconds, score better than 15/21/17 mpg city/highway/combined on the EPA cycle, and tow more than 8,300 pounds. None of that should be hard, as the old ’Gator hit 60 mph in 6.2 seconds with less power, scored 15/20/17 mpg at the EPA, and towed 9,000 pounds. When asked about other engine options from the stable, a Lincoln representative said Navigator customers aren’t looking for any less power.
The 2018 Lincoln Navigator will go on sale late this year. Given the level of improvements over the outgoing ’Gator, we expect the old $64,000 starting price to climb significantly closer to the Cadillac Escalade’s $74,000 entry price.
In addition to the Navigator, Lincoln is investing in new perks aimed at winning over luxury buyers.
Lincoln said its at-home test drive service will expand beyond the Dallas area. Another service, dubbed Lincoln Chauffeur, allows Lincoln owners to book a personal driver for their own vehicles. Lincoln Chauffeur recently launched as a pilot program in Miami, and it will arrive in San Diego in the next few weeks.
With the revival of the Continental, Lincoln started a pick-up and delivery program that comes standard with new models.
This summer, Lincoln will begin a partnership with The Surf Lodge in the Hamptons, the exclusive New York hotspot.
swanson799.00
      04-12-2017, 01:38 PM   #2
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
((Chuckle)) Well, now we know what the well heeled drug dealers will be driving soon
also, there's a land yacht joke in there somewhere...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
RABAUKE4636.50
      04-12-2017, 01:51 PM   #3
TXSTYLE
"Salud"
TXSTYLE's Avatar
Spoken like a true simple minded hater.
swanson799.00
      04-12-2017, 01:53 PM   #4
Red Bread
Drives: Smog machines
I hate all SUV's, but that's as pretty as a pallet of fresh lumber.
RABAUKE4636.50
SakhirM410803.50
ShocknAwe3586.00
RM73034.00
      04-12-2017, 01:56 PM   #5
Beartato
Beartato's Avatar
888
Drives: M235i
That looks comfy as heck.
      04-12-2017, 02:05 PM   #6
TXSTYLE
"Salud"
TXSTYLE's Avatar
But see, I love me some fresh lumber too. Reminds of smoke which reminds me of BBQ which reminds me of good eating!
Red Bread4458.00
swanson799.00
      04-12-2017, 02:07 PM   #7
1and1
Loves me some MHD!
1and1's Avatar
'09 135i  [10.00]
lolz Nah, not a hater, but you'd be right to say they aren't my style- I'm more fighter pilot than commercial airline driver for sure.
Still, gotta appreciate it for being a whole lotta good at what it is. The wheels are a touch fugly, and not much for the tacked on tablet in the center console look that's somehow become standard, but I bet those seats are more comfy than the sofa in my living room...
1and1
      04-12-2017, 02:08 PM   #8
ChuckAWDM2
ChuckAWDM2's Avatar
176
Drives: 2024 M240ix
pass
2024 ///M240ix |
      04-12-2017, 02:09 PM   #9
TXSTYLE
"Salud"
TXSTYLE's Avatar
Last I checked... Our roads aren't entirely made up of twisties and tracks. When I have a hour plus of driving or riding to do with my family, give me a big, plush, comfy, cushiony ride all day everyday. Especially with traffic figured in.
Beartato887.50
swanson799.00
      04-12-2017, 02:22 PM   #10
obert
obert's Avatar
Drives: 2013 328i
What a pile of shit
jkoral1133.50
      04-12-2017, 02:31 PM   #11
9krpmrx8
Clean is the new cool, keep it that way.
9krpmrx8's Avatar
814
Drives: 11' Alpine White 335i Sedan
Just another boring SUV, at this point they all look the same.
      04-12-2017, 02:35 PM   #12
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
That'll be super useful when commuting you and your grande latte to work - which is generally what i see driving these monsters.
      04-12-2017, 02:40 PM   #13
SHoTTa35
Drives: F30
Nop nop nooope!
I'll take a Jaguar instead.... Those wheels .... nope!
      04-12-2017, 02:46 PM   #14
jpdchicago
jpdchicago's Avatar
Drives: M4 CSL, X3MC
Looks like a big minivan to me...
9krpmrx8813.50
      04-12-2017, 03:06 PM   #15
Germanauto
Germanauto's Avatar
Drives: Alfa Romeo Giulia, Rosso
Very impressed with the interior.
Exterior looks overstyled and odd in places.
But overall nice job. The current Navi has been around for like ~12 yrs now and has been long forgotten by people for a good 5-6 yrs.
TXSTYLE14989.00
      04-12-2017, 03:38 PM   #16
Zeroblade
Explodes on impact
Zeroblade's Avatar
Drives: 2006 Mazda3
Looks like a gigantic Ford Flex
Yea... yea I got an M(azda)3.... <.<
*work in progress*
      04-12-2017, 03:39 PM   #17
TXSTYLE
"Salud"
TXSTYLE's Avatar
Lightbulb
Originally Posted by SHoTTa35 View Post
Nop nop nooope!
You do realize the Jag is half this size? I like the F-Pace, it's just too tiny for hauling anything significant.
Factory wheels are NEVER an option for me.
      04-12-2017, 03:47 PM   #18
ORIGIN M.
Drives: ///M
Because rolling couch... Or moving brick wall.
      04-12-2017, 03:47 PM   #19
euro*
euro*'s Avatar
Drives: F90 M5
i think it looks ugly, especially that interior due to all those stitched lines across the seats. Looks tacky as hell to me.
But hey, if you like it, why not? its your money
      04-12-2017, 03:51 PM   #20
KingOfJericho
KingOfJericho's Avatar
Drives: Yes
2010 135i Coupe  [5.26]
I wanted to like this but I can't. It's literally the worst looking vehicle in the Lincoln lineup, which is otherwise extremely attractive.
Also, if they're shooting for upscale, why baby blue on baby blue for the press release?!
      04-12-2017, 04:07 PM   #21
scoobysaurus
A Raptor version of this would be great! Gorgeous SUV nevertheless. Haters just don't understand the appeal of a full sized BOF truck or SUV.
TXSTYLE14989.00
swanson799.00
      04-12-2017, 04:40 PM   #22
TXSTYLE
"Salud"
TXSTYLE's Avatar
I actually like the exterior color a lot! I personally would want/chose a deep saddle/cognac interior for a nice contrast.
