04-18-2017, 07:36 AM | #1 |
Rep 124
Drives: F87 BSM M2
Xpel vs Vinyl Wrap
Would they be similar in protecting the paint? Would a vinyl wrap just allow me to do a different color? Trying to understand the pros and cons of each.
04-18-2017, 09:39 AM | #2 |
Rep 3,953
Vinyl wrap does not provide the same protection as a clear bra.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
04-18-2017, 02:24 PM | #3 |
Rep 6,635
04-18-2017, 03:01 PM | #4 |
BMW Newb
582
Rep 903
I would say maybe 10%. Its not meant to be protective...its purely cosmetic....vinyl wrap is pretty thin. I've seen pebbles and rocks go right through and tear small holes in a wrap on gravelly roads and cars ahead kicking up debris.
04-18-2017, 03:03 PM | #5 |
Rep 6,635
Seems like that would get ugly really fast as it would show the original paint or worse through the tears in the vinyl. Do people who wrap their cars do something to stop this from happening?
04-18-2017, 03:28 PM | #6 |
Rep 356
Drives: MY17 BSM M2
Vinyl wraps do offer some protection. It mainly protects the paint from UV damage and getting sandblasted on the highway or whatever elements it's exposed to. So it will protect your paint to a degree.
However, most wrap vinyls are only warrantied to about 3 years (vertical panels). It's even less if you're living in an area with hot summers. And in areas like socal, arizona, etc. where temps reach 110 degrees, horizontal panels like hoods, roofs and trunk lids will receive a 1 year warranty at most. Another factor is that vinyl is not self healing. If it gets a scratch or scuffed, you either live with it or replace the whole panel. I've never had a car with a full clear bra so i can't give a comparison to a vinyl wrap but I have wrapped and removed the wrap from my 228 a couple times since i got it. And from my experience with my personal car, the vinyl did a very good job of protecting the paint from rock chips and other damage. A few months ago I was in a parking lot and someone dinged my car with their door. It didn't leave a dent but it did scrape about a 1/2" section near my door handle. The vinyl tore and i could see the paint but the paint was undamaged. Another note, recently wrap shops have started using ceramic coatings on their wraps to offer another layer of protection and security to their customers. This of course is an additional charge, but it helps keep the wrap clean and offers a bit more peace of mind. CeramicPro even has a product developed specifically for vinyl and PPF films. However, from what i've heard, applying ceramic coatings to the vinyl may void the manufacturer warranty on the vinyl. Many shops have applied ceramic coatings to vinyl and I haven't heard of any issues yet so the voided warranty from 3M or avery may be a non-issue.(i'm planning on wrapping my M2 when i receive it and applying ceramicpro to the vinyl to test how it holds up.) So to summarize, if you are only looking to protect your paint go with Xpel. If you want to change the color of your car and still get a bit of protection on your OEM paint, wrap it. If you want to change the color and get a bit more protection, get a ceramic coating over the wrap. And if money is no object, you can always wrap the car and then put xpel over the wrap.
04-18-2017, 04:47 PM | #7 | |
Rep 124
Drives: F87 BSM M2
Thanks for the input. I appreciate the thoroughness. I wish I could Xpel Stealth the whole car, but a little steep for me. Therefore, I decided to do the full front (bumper, hood, front fenders, mirror caps) and possibly side rocker panels. |
04-18-2017, 05:20 PM | #8 |
Rep 356
Drives: MY17 BSM M2
Of course. Have you considered expel on the rear quarter panel? I know it's probably quite a bit more expensive but i've heard that the rear fenders on the M2 take a beating
04-18-2017, 07:45 PM | #9 |
Rep 228
Comparing 3M/Xpel to a wrap is like comparing a condom to a sock. If it's protection you are looking for play it safe. You can pour some nail polish on a sock. But at the end, it's just a shinny sock.
04-18-2017, 09:09 PM | #10 |
Da Baus
283
Rep 259
Regarding what someone mentioned above; you cant xpel over vinyl. Vinyl has an expiration date ranging 3-5years from application depending on exposures.
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
fourtitude4.50 |
04-18-2017, 11:13 PM | #11 |
Rep 356
Drives: MY17 BSM M2
@supersam well, it's not that you can't.. It's more that it would be a waste of 10k. You could xpel the wrap and it would have to be removed after 3-5 years as opposed to the 10yr warranty that xpel gets.
04-19-2017, 08:23 AM | #13 |
Rep 124
Drives: F87 BSM M2
You should be able to use warranty. I think it depends on the installer. Found a great shop in Houston has a very good relationship with Xpel and would replace it without a problem.
04-19-2017, 10:06 AM | #14 |
Rep 527
04-19-2017, 10:58 AM | #15 | |
Rep 412
And my second choice would've easily been Gulf Coast Auto Shield. |
04-19-2017, 12:20 PM | #16 | |
Rep 6,635
04-19-2017, 12:34 PM | #17 |
Rep 412
And slightly thicker than the previous version. They're owned by Eastman Chemical who also owns Huper Optik, Llumar, and Autobahn ....
04-19-2017, 12:50 PM | #18 |
Rep 124
Drives: F87 BSM M2
Gulf Coast is installing Xpel Stealth. I always wanted a matte/satin finish car and decided to just do it.
04-19-2017, 06:09 PM | #19 | |
Rep 124
Drives: F87 BSM M2
9442 Summerbell Ln, Houston, TX 77074 Feel free to check out my M2 once he completes the Xpel Stealth. Here are current progress pics: Test fit Comparison Xpel Ultimate on top and Xpel Stealth on bottom. Plus a GT3RS. Did xpel ultimate wrap only on the front. hood, fenders, bumper, mirror caps |
04-19-2017, 06:35 PM | #20 |
Rep 6,635
04-19-2017, 06:54 PM | #21 |
Rep 124
Drives: F87 BSM M2
Yes it has the self healing technology like the Ultimate. He did say tho due to the satin finish on the film, the healing isn't as good as the clear.
04-19-2017, 07:08 PM | #22 |
Rep 356
Drives: MY17 BSM M2
It's looking great! Congrats!
