Water pump doesn't immediately circulate coolant?
04-18-2017, 07:59 PM | #1 |
Rep 81
I read somewhere it doesn't turn on immediately in order for the engine to warm up faster from a cold start. Is this true or not? I'm arguing with an arrogant mechanic friend who thought the thermostat is behind the oil filter housing and claimed you have to remove it to get to the thermostat. I was laughing at him and told him that's why regular mechanics mess up bmw's when they try to work on them.
04-18-2017, 09:30 PM | #2 |
Rep 81
04-18-2017, 10:22 PM | #3 |
Rep 81
I tested it earlier today. My car was overheating but it suddenly stopped overheating and drove 300 miles back home with no issues, either something started working again or there was a block in the coolant passages. I turned it on with the reservoir cap off and after about one minute I saw the the stream of coolant at the same time the coolant level rose and spit all the coolant out. Pieces of the plastic floater flew out.
04-18-2017, 10:41 PM | #4 | |
Rep 472
I have a HUD that connects to obd2 and it also shows water temp. it seems when the water temp reaches about 220F ish, it starts to go down to about 180F ish and than back to 220F ish. this repeats over and over again. so I think you can pretty much guess when the thermostat opens and closes and when water pump turns on and off. |
04-19-2017, 03:00 AM | #5 | |
Rep 589
Google "N52 training pdf" and the top result should be an attachment from this forum. It's a technical training document directly from BMW. See the section around page 54 for a detailed description of the management of the cooling system. It will describe it better than any of us would. Also, what he may have been referring to is the thermostat inside the oil cooler on the N54/N55. It sounds like he was just wrong, but he may have been confusing the actual thermostat with that thermostat inside the oil cooler. |
Wolf 3352368.50 |
04-19-2017, 07:22 AM | #7 | |
Rep 3,560
04-19-2017, 08:54 AM | #8 | |
Is it the shoes!?
3885
Rep 5,112
- The thermostat is located behind the water pump, under passenger side of the car - If you remove the oil filter housing, you will find some large holes for oil and coolant - Anyone who removes the oil filter housing to get to the thermostat on a BMW is dumb |
04-19-2017, 08:58 AM | #9 |
Rep 14,829
I've always felt that since 2007, the 335i warms up faster than any car I've ever owned, and that there is heat by the time I reach the end of my driveway, and I don't exactly live at Southfork...this implies to me the water pump did not circulate coolant upon starting...
04-19-2017, 11:15 AM | #11 |
Rep 2,835
Okay, some of ya'll lack logic and mechanical knowledge.
Just because the water pump is running does not mean the water is flowing through the engine block. That is why there are valves and recirculating lines. Coolant will not flow past any thermostat until the operating temperature is reached in the engine. This does not matter whether it's a mechanical, electrical or spring controlled thermostat. And if you want to screw up an engine, completely bypass or remove the thermostat. |
04-19-2017, 01:04 PM | #12 | |
Rep 5,022
Anyone can work on BMWs with training. They're nothing special. You knew nothing more than this "regular" mechanic. You had a hunch and you had to come here to verify it. If this mechanic spent any time working on or reading about BMWs (your area of expertise) he'd have known better. You don't know what you don't know. |
04-19-2017, 04:48 PM | #13 |
Rep 81
I did the venting procedure (hold gas pedal for 10 seconds with engine off) and watched the stream in the coolant tank and the stream is intermittent. Every three seconds it pumps coolant for about one second. Should this be a continuous stream during the venting procedure or is my water pump going bad? Car is overheating sometimes, but sometimes it's fine.
