TPMS Malfunction
04-19-2017, 06:28 AM | #1 |
Rep 712
TPMS Malfunction
I just swapped to coilovers and changed front/rear bumper and now I have this warning on the iDrive saying TPMS Malfunction. I double checked both of the front sensor boxes in the fender well and they are both plugged in.
Anyway to tell what exactly is causing the issue? |
04-19-2017, 06:58 AM | #2 |
Rep 952
Did you already try a TPMS reset and that did not fix the issue? If the reset does not fix the issue, you'll need to scan for codes.
bone stock
04-19-2017, 10:25 AM | #3 |
Rep 712
04-19-2017, 11:09 AM | #4 | |
Rep 342
The sensors are mounted on the inside of the wheel well liners, so if you removed the bumpers, it's likely that one of the connections to a sensor came loose. Did you check the rear connections? |
04-19-2017, 03:21 PM | #5 | |
Rep 712
I will have to find INPA download again and put it on laptop. |
