e92 available steering upgrades?
04-20-2017, 11:27 PM | #1 |
Rep 12
Hey guys,
I just posted in the coding section to see if there were any answers over there. I want my steering lighter, i was looking into upgrading steering racks but the only upgrade seems to be the M3 rack retrofit. It seems that that would make my steering stiffer because the servotronic wouldnt work properly. Do you guys know of any upgrades to make my steering a little lighter? thanks |
04-20-2017, 11:32 PM | #2 | |
Apprentice
373
Rep 801
Really the E90 has an awesome steering system. When I first got my E93, I was thought the steering was a little heavy but man, after driving that and going to any other car I was shocked on how perfect the E9x steering is. |
04-20-2017, 11:40 PM | #4 |
Rep 159
04-21-2017, 03:50 AM | #6 |
Rep 2,773
e90 have electric steering rack with 320d, 330d and x1 and z4 with new n20 engine
another options is try active steering rack, it is have servotronic built-in
04-21-2017, 05:20 AM | #7 |
Rep 12
Maybe parts of the steering rack are electric but I know we also have power steering pumps... But ya if I get an M3 steering rack with servotronic then I have to figure out how to hook up the servotronic
04-21-2017, 07:44 AM | #8 |
Rep 1,783
Also put a few hundred pounds in the trunk to keep weight off the tires. And you know the max weight that they say you can carry in a car? Well you can easily go over it by 1000lbs a BMW engineer even said so himself.
04-21-2017, 08:11 AM | #9 |
Rep 89
I know what you mean. I didn't notice how heavy the steering was until I got back into my old DD and was like WTF is wrong with the wheel?!! I can steer with my pinky.
I like the tight feel of the steering in the e90. I feel like there is more driver control and just feels super nice. |
04-21-2017, 08:21 AM | #10 | |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
Also I would suggest to lift some weights, the E9x has very good hydraulic steering.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
04-21-2017, 08:35 AM | #11 |
Rep 14,829
Interesting, and probably the OPs opinion is why E9x steering is gone. But the F series is extreme, I drove a loaner for over 4 mos. It's lighter than my 98 Maxima. On business, I drove 2017 Malibus and a 2017 Pathfinder, both these cars have eps and they felt ok, almost too little assist at low speeds with the pathfinder. E9x steering RIP...
04-21-2017, 09:28 AM | #12 |
Rep 12
Well guess I'll just concede that my opinion is wrong. I might try some stuff in the future and keep you guys in the loop if I find anything that works for those who feel the same as me. I'll start with adjusting alignment and then adjusting front chamber slightly. I wonder if the m3 front control arm kit would do anything.
04-21-2017, 10:19 AM | #13 | |
Is it the shoes!?
3885
Rep 5,112
Antetokounmpo1551.50 AWDBooSTIn90148.50 |
04-21-2017, 10:53 AM | #14 | |
Rep 1,783
04-21-2017, 10:57 AM | #15 |
Rep 12
I really appreciate this input. Never thought of a heavier steering wheel. Thanks
04-21-2017, 10:58 AM | #16 | |
Rep 5,016
The standard e9x steering is needlessly stiff at parking lot speeds. Of course, that's just my opinion. |
04-21-2017, 11:08 AM | #17 |
Rep 1,157
Chug some redbull and your steering won't feel so heavy!!! Lol
If you are going drifting get some skinny ass tires... skinny tires on the steering wheels will decrease effort. And since you will be going(relatively) slow get some camber/castor plates and dial out some caster. It will lighten your steering but will have other effects on your handling(at speed stability being one of them)... |
04-21-2017, 12:18 PM | #18 | |
Rep 1,003
Drives: 16 340i, 15 X3d, 91 318i
As for the drift event, I bet you'll find it's not as bad as you expect. Flicking the car around lightens the front end and the tires pretty much steer themselves in transition once the slide is initiated. |
Fritzer944.50 |
04-21-2017, 12:29 PM | #19 | |
Rep 1,783
04-21-2017, 12:53 PM | #20 |
Rep 12
Ya I will do all that thanks. I thought this weighted steering wheel thing was something I hadn't heard of yet. Weighted shift knob weighted steering wheel.. same concept right? Lol
04-21-2017, 02:37 PM | #21 | |
Rep 595
04-21-2017, 06:00 PM | #22 | |
Rep 2,529
Drives: 2011 328i Wagon
The VW Golf GTI that replaced the M235i has about a perfect mix (and EPS at that), though I actually wish the steering ratio was a bit slower - it is on the verge of being nervous. <2 turns lock to lock.
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option '11 128i Convertible - Space Gray on Savannah Beige, 6spd manual, also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire |
tlow982192.50 |
