Wheel Alignment Results
04-21-2017, 10:11 AM | #1 |
Rep 80
Anyone interpret this Laser Alignment for me, as unsure of what it means, good bad, indifferent?
where to upload high resolution photos Last edited by 1916; 04-21-2017 at 10:18 AM.. |
04-23-2017, 04:13 AM | #5 |
Rep 74
04-24-2017, 09:24 AM | #7 |
Rep 1,959
Drives: E90 M3 LCI Jerez Black
Mine had to be changed due to seizing.
05-08-2017, 11:57 AM | #9 |
Rep 462
Basically it's bloody awful!
Tierod seizure is common, and the first thing you do before aligning anything is make sure that the bolts and arms are loose and moving. At least thats what I do and something you can check before taking your vehicle for alignment. I have freeed many a track road end with WD40 and careful persuasion (take the torx bolt out and carefully enlarge the split that is there - do not damage the threads), if that fails I generally get a plumbers torch out and hit the track rod with some heat in 5 Minute bursts... Oxy would be a last resort on the list, but Kwickfit usually go there first... |
