04-21-2017, 05:49 PM | #1 |
Rep 66
idrive controller knob mod.
So I bought this controller knob cover from amazon. It turned out really good! I hated the smaller knob.
04-21-2017, 10:44 PM | #3 |
Rep 66
04-21-2017, 10:48 PM | #4 |
Rep 66
n55silverado12.00 |
04-22-2017, 04:57 PM | #5 |
Rep 3,863
I bought the same from eBay (Hong Kong) and it fitted in 5mins and great upgrade rather than spending fortune to change whole thing
04-23-2017, 08:50 AM | #7 |
Rep 158
But if the car has the small knob wouldn't this one just cover up most of the buttons? It would have to extend over and make the function buttons less visible.
04-23-2017, 01:29 PM | #8 |
Rep 66
Nope. Even when the smaller knob was on it, it still had a larger circular trim under it. The larger knob is the same diameter as that circular trim. Basically ends up being the exact same dimensions as if it came that way.
04-28-2017, 08:30 AM | #10 |
Rep 3,863
04-28-2017, 09:50 AM | #11 |
Rep 66
04-28-2017, 11:42 AM | #13 |
Rep 166
Thanks i'll try a razorblade or something alike than.
(@ the pictoral guide: I knew how it's supposed to be done, mine just seems to be stuck) |
rjoelshipp21.00 |
04-28-2017, 11:51 AM | #14 |
Rep 66
The only concern I had when it was done was the fact that you don't really get a good sense of whether or not it is fully installed. There is no "click" or "snap". It just presses down on the smaller controller. But it works.
05-01-2017, 11:01 AM | #15 |
Rep 2
Hi...i am a new user here. Even i bought this, so as per my observation when the smaller knob was on it, it still had a larger circular trim under it. The larger knob is the same diameter as that circular trim. Basically ends up being the exact same dimensions as if it came that way.
print circuit board assembly Last edited by LulaNord; 05-18-2017 at 11:38 AM.. |
05-13-2017, 09:37 PM | #16 |
Rep 126
Will these dials replace/work on the F30 non-navi setup? My non-navi setup only has 3 buttons across the top as seen in the picture. It only allows for left/right movement (no up and down).
05-13-2017, 09:43 PM | #17 |
Rep 66
I don't think they will. The new knob grabs onto the silver Navi version knob. It slides over it and in between the various grooves of the existing handle. I could be wrong. But I don't think so.
05-14-2017, 03:08 AM | #18 | |
Rep 3,863
No it won't fit on top of this Idrive , it says in the eBay listing as well |
05-15-2017, 08:56 AM | #19 | |
Rep 265
Check this link: https://www.aliexpress.com/item/iDri...f-8608ed00acbb And select Color name: B What has stopped me from purchasing this is the print on the knob itself. On our knob the top part spins, which would make the print turn around too. If they would sell one without any print I would buy it! |
05-16-2017, 06:28 AM | #21 |
Rep 265
05-16-2017, 12:43 PM | #22 |
Rep 166
Can someone please tell me how big the gap between the knob and the base of the idrive is supposed to be? Mine 'floats' about 5 to 7mm (estimate, not measured) above the base and i think the gap should be smaller... Also, does anyone finds the big knob to be noisy? I can hear the plastic top rubbing against the ring. I put some adhesive felt on the underside of the top wich improved it a little, but i think it still sounds cheap. I'm also going to stick some sound deadening material to the top trying to eliminate the annoying sound...
