Bad valve cover N52 2006 question
04-23-2017, 01:09 PM | #1 |
Rep 80
Greeting I have bad valve cover. Car is N52 325i 2006. Car run ok so far little bit of rough idle. Planning to change it in month or so. My question is it bad for the car in main time to commute to work etc? Cheers
04-23-2017, 01:19 PM | #2 |
Rep 471
I'd change it ASAP. It might get worse. I would not wait a month to do something like this, but if I was tempted or had to, I would open the hood before every drive and observe if it is getting worse or not. Nothing good will happen by waiting, except you can delay paying for the repair.
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
05-06-2017, 10:11 PM | #3 |
Rep 244
Drives: 2006 330i Manual
When you say the valve cover is bad, what is wrong with it?
VTECaddict481.00 |
05-06-2017, 10:29 PM | #4 |
Where'd my VTEC go?
481
Rep 6,067
Yes, what is wrong with it? If it's seeping oil at the gasket, you can probably wait a little while. If there's a hole and you can see the cams, probably best to fix it ASAP...
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-09-2017, 05:53 PM | #6 |
Rep 385
If it's a plastic one, the PCV is built into it, and the rubber diaphragm can deteriorate causing a ridiculous screeching sound followed with a rough idle. Ask me how I know
2012 E91 MSPORT • ST COILOVERS • TSW BATHURST |
