BMW FSC File Generator 1.0.2
04-24-2017, 02:14 PM | #1 |
Rep 9
Hey folks,
since this forum has helped me a lot to successfully create my first FSC, I would now like to return the favor and give you guys a tool that completely automates the HEX editor part. That means, the executable creates your 319-bytes FSC file from the file that you've retrieved from your car (e. g. 'generalPersistencyData_diagnosticSWTController' or 'data03'). I've written this application myself. For this reason, I ask you guys for feedback on wheter it is functional and how you like the idea! Of course it's completely free and you may use and distribute it just as you like. Please just leave a credit to me, thomasx, or this topic here. Usage ========== The tool is a dos executable. There are two ways to execute it: 1. Call it via cmd and put your input file as a command line argument. Code:
BMW_FSC_File_Generator generalPersistencyData_DiagnosticSWTController ========== If your input file is valid, the 319-byte FSC file will be created in the folder the tool was started from. It will be named after your short vin. For example: AB12345.fsc The tool now works for both CIC and NBT cars (1B and DE files). Have fun with it and don't forget to share and give feedback! thomasx Last edited by thomasx; 04-25-2017 at 10:29 AM.. |
04-25-2017, 11:26 AM | #5 |
VAG Survivor
40
Rep 150
Is that fsc for maps upgrade ?
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
06-16-2017, 02:09 PM | #7 |
Rep 293
Drives: 2008 E93 M3
What about for PPK Flash?
03-09-2021, 05:15 PM | #8 |
Rep 2
Re: BMW FSC File Generator 1.0.2
The file attachment in post #1 on this thread contains a Trojan called 'Occamy.CA7'. Fortunately W10 picks it up and quarantines it. If it worked it must have got compromised or else it is a false positive.
01-12-2023, 01:01 PM | #9 | |
Rep 10
Tags |
bmw, file, fsc, generator, map |
