Supercharger On 3 Stage N52?
04-25-2017, 11:27 AM | #2 |
Rep 202
Still would be slower than a n54/n55 but this is better asked in the n52 section. If you really want to have a fun car to drive then why not buy somthing for the weekend and keep the 5 series as a daily? You could probably buy a miata or 350z for not much more than the supercharger
04-25-2017, 11:41 AM | #3 | |
Rep 2,825
but I really want that modded inline 6 the main goal for me is to have that unique great sounding naturally aspirated 6, even thought I wont be any faster then a 335i and I wasted alot of money I will be enjoying myself just as much. I think I can get close to 280HP and 240 torque to the crank with catless headers and an ECU tune because I already have a 3 stage manifold from the factory. but you are right. I am thinking of looking into an rx8. |
04-25-2017, 12:42 PM | #4 |
Rep 2,293
By 3 stage you mean intake / headers / tune combo right
That alone would get you in the 270-290 crank hp on the higher end if you have an exhaust system , and other small mods. Now as far as i know the ess supercharger does not work the aa headers or any other after market headers. Ess is not able to come out with the proper tune so they just stopped trying and flat out said you have to remove the headers to get their supercharger to work properly Ess supercharger stage 2 should get you to around stock 335 . I believe they dynoed at 285 whp . And that was on the stage 1 if i remember correctly. With their stage 2 you should be above 335 power by a bid. Although you could always pick up a second fun car for 10k . Like someone said 350 and even 370 are around that prize. As well as early models 335 |
Mr._E4.50 |
04-25-2017, 01:33 PM | #5 | |
Rep 2,825
apparently a supercharger does not work with the 3 stage manifold. and it doesnt work with headers either??? fuck it, I will just get catless headers and eventually buy a little weekend toy. |
04-25-2017, 01:37 PM | #6 |
Rep 394
holy shit man your posts are awful.
12
Bimmer 808170.00 bigchieftaco29.00 ThugzZ BunnY681.50 Mashman118.00 justpete1234.00 Mike.2045.00 bsmoov217.50 max_330i340.00 Vincent_E9080.50 Johnny Boost323.50 Antetokounmpo1551.50 Torgus3781.50 |
04-25-2017, 01:47 PM | #7 |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
this guy is just trolling. posts in here all the time, doesn't have an E90.
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
04-25-2017, 03:11 PM | #8 |
Rep 1,155
why are you asking questions? no one on this forum knows as much as you do. you have over 2400 posts since November, I think that means you are a bmw master tech now.
Bimmer 808170.00 justpete1234.00 Mike.2045.00 bsmoov217.50 max_330i340.00 Johnny Boost323.50 Antetokounmpo1551.50 |
04-25-2017, 05:05 PM | #9 |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
It would probably be easier/cheaper to just buy an older 335i instead of supercharging an N52 and getting it to run correctly.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
Captain comic156.50 Johnny Boost323.50 |
04-25-2017, 06:10 PM | #10 | |
Rep 380
Even BPC themselves gave up and said that it can't be done with reasonable money. Last price point they were at was around $10k and they still couldn't do it. They still required other parts to be upgraded and it ended up not feasible for mass market Now that BPC Turbo kit is out, all we have is Supercharger, but there are many Cons: 1. It's still expensive $5k + install 2. Even after all is said and done - you can still have issues (heck even ESS car is still plagued with rough idle and some other issues) 3. Arguably gains are low and some have showed that on lower rpms SC is even robbing the power instead of adding. You are arguably getting around 20-70hp max, but no one actually dyno to prove it. That 70hp at max rpms 7000 is basically a joke. That is a 50whp at the wheels at max rpms - assuming everything else is working ideally. In real life scenario when driving in under 5500 rpm - you will be lucky to even get 15-35hp lol Bottom line is - that's why SC is not popular. However, ESS is starting to make some threads about it now, when they saw BPC fall short on their Turbo kit. They probably have unsold stock that they are desperate to get rid of Selling a 328 and adding same $5k will get you a 335 that will have 306hp stock (and bigger brakes and rotors, beter stronger tranny) and then you can get it up to 500hp with only $1.5k - now that is a real gain if you ask me Last edited by Captain comic; 04-25-2017 at 09:40 PM.. |
04-25-2017, 09:52 PM | #12 |
Rep 642
This is the same guy who told people to get coilovers then recommends lowering springs.
Then he got called out on it and he says spring and quality shocks/struts are the same thing as coilovers. LOL. Never forget. |
WhiteBeard151.00 Bimmer 808170.00 ThugzZ BunnY681.50 RileyZ19.00 ritzzzzzwik234.00 Antetokounmpo1551.50 Johnny Boost323.50 |
04-25-2017, 10:07 PM | #13 | |
Rep 535
His posts are sometimes reasonable, but often are so twisted minded that you often wonder if it's a kid writing all his posts or just an idiot adult LOL |
04-26-2017, 01:30 AM | #14 |
Rep 81
He's close to 300 hp, that supercharger only adds 30ish horsepower? That sucks I thought it would get you to around 350-400.
If you want some power out of that N52 just add a wet nitrous system with a switch that engages only under WOT. But your tranny is going to take a poop. My dream machine is a 325i with carbon fiber m3 front and rear fenders bumpers, doors, hood, roof, all interior plastic redone in carbon fiber by making molds and wrapped in leather with sound deadening as well, and a Buick 215 V8 stroked to 5.0 with forged internals and a supercharger. And of course m3 everything suspension wise, with giant Porsche brakes. And of course same auto transmission but every part 3d laser scanned and cnc'd out of forged materials. So I can torque brake because I love doing that. That's what I will do if I wins the lotto. |
04-26-2017, 02:39 AM | #15 | |
Rep 545
04-26-2017, 08:40 AM | #16 |
Rep 647
All this guy does is regurgitate people's past posts in this forum and tries to sound like he knows what he's talking about. He will never have a fast car and is too stubborn and stupid to take the advice to get a cheap 335 or 535. He's beaten the N52 engine and drivetrain sub forum to death with his posts. Someone please ban him so we can get back to normal around here.
04-26-2017, 10:45 AM | #18 |
Rep 81
04-26-2017, 12:15 PM | #19 | |
Rep 649
Drives: F80
04-26-2017, 12:28 PM | #20 |
Rep 482
Since when is the rx8 inline6?
Thought it has that rotary junk in it.........
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
04-26-2017, 01:08 PM | #22 | |
Rep 2,825
love them all man. I want something light and nimble. should have went with a 335i its still heavy but the perfect compromise between luxury and sport compared to the f10. |
