Remove (standard) steering wheel airbag...help!?
04-26-2017, 06:26 AM | #1 |
Rep 18
Folks, I apparently have a faulty driver airbag module (per code, seat-sensor contact-cleaning, and finally shop diagnosis): While a fairly adept DIY'er on all five of my bimmers, I have been stymied in removing this E90 steering wheel SRS, to swap the module and clockspring! 'And no...unfortunately this VIN was not a recall candidate
The videos and reading/RealOEM suggested pushing the internal "prongs" with a long shaft screwdriver-torx; seemingly straightforward. First, the two entry-holes appeared plugged (e.g. vinyl not opened 'yet'), then upon insertion, the tool used didn't seem to penetrate to the depth implied on the videos <?>. After fishing around, trying to lever anything that felt like a spring-tension-clip...no joy. Before I attack it again with more vengence, is there any guidance on a best screwdriver or pick, how far the tang should be, etc? So far, I have only succeeded in beginning to tear the vinyl around the access holes. ...THX for any insights! Last edited by moapys; 04-26-2017 at 07:04 AM.. |
04-26-2017, 09:16 AM | #2 |
Rep 2,835
04-26-2017, 01:11 PM | #4 |
Rep 2,835
04-26-2017, 06:26 PM | #5 |
Rep 18
Thx, GrayFox...yep; Pelican is always a first go-to
...I'll give it another shot with a slimmer tool; it's possible that the ones used had a bit too much diameter to get "the feel".
Finding a replacement squib-bag and clockspring/slipring is going to be a treat, too - there's a dozen variations of parts depending upon electronics options (sigh). Thinking, at this point, I yank, get p/n's, reassemble and wait for replacements. Otherwise, 'Murphy' will surely send me the wrong clockspring assembly! 'More, as things progress... |
04-26-2017, 06:33 PM | #6 |
Curmudgeon and Pedant
690
Rep 3,489
04-26-2017, 06:44 PM | #7 |
Head Fry Cook at McBurgertown
507
Rep 1,005
I used a long, thin flathead screwdriver when I did a non-sport conversion.
Took me quite a while. After one side pops loose, you should be able to pry it back far enough to use a flashlight to get a glimpse of what it was you were pushing against to release. After that, it's easy to use that mental image to guide you to pop loose the remaining side. Using that method, the second side goes quickly. |
04-26-2017, 06:47 PM | #8 |
Rep 4,203
Drives: '11 335is | '16 Macan Turbo
Dude, grab a long flathead.... stick that long driver in the hole flat end vertical... push towards you. 6 seconds
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
04-27-2017, 07:04 AM | #9 | |
Rep 2,835
They must have changed something in the LCI's. Last edited by Greyfox; 04-27-2017 at 07:10 AM.. |
04-27-2017, 10:01 AM | #10 |
690
Rep 3,489
04-27-2017, 10:22 AM | #12 |
Rep 2,109
OP, use some patience and fiddling, you will remove it very easily.
And to find out exact part for your model, check your production date of your car. It should be printed on the driver side door jamb. If you can't find it I think online BMW VIN decoders will also tell you. Then go to realoem.com and choose your model and your production date for your model then look for the part number. |
