2nd gear synchro 6mt
04-26-2017, 02:58 PM | #1 |
Rep 197
Hey guys,
I was wondering if anyone's replaced the 2nd gear synchro and how much it costs? Cant seem to find a clear price on the forums. I know under warranty they just replace the whole tranny but I'm out of warranty so I was wondering the cost of anyone has done it before. Ive tried changing the fluids but it didn't help so I guess it's the synchro Thanks!! |
04-26-2017, 03:14 PM | #2 |
Rep 922
a) change trans fluid again and hope for the best
b) skip 2nd gear or c) transmission rebuild ($$$$$) depending on how serious it is and how much it bothers you, the only real fixes are the rebuild or dumping the car for one with an unmolested gearbox. Sorry to break the bad news.
2006 330i 6MT Jet Black / Black
04-26-2017, 03:19 PM | #3 | |
Rep 2,825
second gear is somewhat important... you cant always just skip it. I'm sure changing a synchro is fairly simple. its not a whole transmission rebuild... OP, I apologize for not being of much help. I suggest you contact local transmission shops and figure out a price. that will be your best bet. doesnt have to be only indy's. |
AWSB328iM398.50 |
04-26-2017, 03:50 PM | #4 | |
Rep 922
Antetokounmpo1551.50 |
04-26-2017, 04:15 PM | #5 | |
Rep 2,825
also, raping it into second gear at redline everyday will wear a synchro must faster then it otherwise would have failed. |
04-26-2017, 04:19 PM | #6 | |
Rep 922
OP-- disregard this guy. He's been trolling these forums for a long time and spouts a lot of nonsense. You will need a transmission rebuild to correctly and permanently fix your worn 2nd gear synchro... there is no way to "fix" a "perfectly good transmission" without removing the unit and some amount of disassembly.
04-26-2017, 04:56 PM | #7 |
Rep 7,215
probably cheapest to just swap in a different 6mt. They don't go for a whole lot on their own, and labor would be similar to doing a clutch replacement (which you could do while you have it apart). You have to R&R the trans to replace the synchro anyway.
Are you sure the synchro is bad though? Could it be something simple like a shifter rebuild? |
Jonah33554.00 HawkeyeGeoff263.00 |
04-26-2017, 05:22 PM | #8 |
Rep 165
Drives: 2011 BSM e92 335i xdrive
Had the same problem. Dealer replaced with a brand new 6mt as bmw doesn't rebuild them. Look for a local bmw specialist to ask about rebuild cost
04-26-2017, 06:36 PM | #9 | |
Curmudgeon and Pedant
692
Rep 3,488
04-26-2017, 07:15 PM | #10 | |
Rep 197
04-26-2017, 07:54 PM | #11 | |
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
04-26-2017, 08:23 PM | #12 |
Rep 762
I've done a few manuals. You should be friendly with a machine shop as there will likely be some pressed on parts that require special fixtures. The nice thing is they only go together 1 way and you can check if it's right before install.
This is not a novice job. You need to be pretty experienced in repairing gear driven devices. And you DO have to take the entire transmission apart. The parts are probably cheap, but may be hard to locate. Good luck OP, you have a task ahead. |
04-26-2017, 08:30 PM | #13 |
Rep 3,191
It's been covered a few times on the other forums, not sure about on here. There are no rebuild kits and you can not buy a new syncro. The only option is to get a new or used trans and hope it doesn't have the same problem.
04-27-2017, 01:58 AM | #14 | |
Rep 5,022
If you did then you wouldn't need to apologize for blabbing about the stars and the moon and the first time you raced with no air filter and how some girl got wet and it smelled funny. |
Antetokounmpo1551.50 max_330i340.00 |
04-27-2017, 09:08 AM | #17 | |
Rep 482
My son's e46 started developing play/noise in 2nd & 3d. At first we thought transmission rebuild. Turned out a relative easy linkage rebuild. Here is a DIY for the e46, but I'm quite positive it's similar with the e90. You don't have to change the shifter per se, but if you want a short shifter, then maybe now it's the time. The most difficult part of the job is to drop the exhaust. Also, as a note, the parts involved are not expensive at all, and I would do that first. You could also check with a reputable indy specialized in BMW's to give you a correct assessment. P.S.: basically all the parts are listed - you need to identify the correct p/n for your car. GL and keep us posted
Stable:
e92is f25 N52 e83 N52 e46ci M54B25 (e53 N62 - sold, R.I.P. e39 M54B30) |
Bluewater328iT86.50 |
04-27-2017, 09:37 AM | #18 | |||
Rep 3,475
04-27-2017, 10:52 AM | #19 |
Rep 5,022
04-27-2017, 12:59 PM | #20 |
Rep 2,607
Drives: 06 330i E90, 18 530xe G30
I agree with the above statements that there isn't such a thing as a quick and easy transmission fix. Nothing about working on a transmission is easy. My buddy had an E92 335xi transmission lose reverse gear, he went the repair route and ended up with a bill for nearly $7000k (now he did replace the clutch while in there) but authorized the work from a generic verbal quote of around $2000 + parts. When the dust settled everything worked great again but was naturally pissed as he could have got a new transmission for nearly the same amount.
max_330i340.00 Bluewater328iT86.50 |
04-27-2017, 01:54 PM | #21 | |
Rep 471
BMWCCA member since 1990
Mods: 330 intake, ECU reflash & tune, Magnaflow cat back resonator & muffler, BMW Euro airbox, tinted windows |
