New VDO WP Cracked?
04-27-2017, 10:42 PM | #1 |
Rep 56
New VDO WP Cracked?
Hey guys,
Just received my new VDO pump from FCPeuro and I don't really even want to install it. Take a look at this pump, it appears they plastiwelded a broken housing cover and sold me a pump for $500. Would you install this? [IMG][/IMG] I currently have a good pump installed with ~70k miles on it...this would be preventative maintenance. |
04-27-2017, 10:53 PM | #2 |
Rep 386
Drives: 08 535xi 11 328xi
If your not happy with the part, return it and get another one. They have a life time warranty on all parts.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
05-01-2017, 08:42 AM | #4 |
Rep 56
Contacted FCPeuro and was told all VDO and genuine BMW pumps have the seam line as apparently the plastic housing is manufactured in two pieces.
Seems like an engineered failure point to me to ensure a steady revenue stream...brilliant, but infuriating! FCP acknowledged my unit looked a bit worse than most on the shelf so I'm getting it replaced....fingers crossed the next one is in better shape. Has anyone tried to reinforce this seam with JB weld? |
05-01-2017, 09:01 AM | #5 | |
Rep 394
05-09-2017, 01:42 AM | #6 | |
Rep 165
Drives: 2011 335is
05-09-2017, 02:05 AM | #7 |
VAG Survivor
40
Rep 150
Yup. Normal. Just installed mine a few months ago. It looked the same as OP
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
05-09-2017, 05:20 AM | #8 |
Rep 772
Drives: 2015 435i grand coupe xdrive
05-09-2017, 12:40 PM | #9 | |
Rep 165
Drives: 2011 335is
If this one cracks, I'll update this post. |
05-09-2017, 01:32 PM | #10 |
Rep 405
My first, second and third one cracked in the same place. I had a 4th one, less than 20K miles and found out after I parted out my car that it too was cracked in the same spot.
05-09-2017, 02:22 PM | #11 |
Rep 56
So I'm the OP and I'm still waiting on my replacement WP from FCPeuro.
So if the one currently installed is not leaking and has 70+k miles, would you replace it with one of the VDO pumps proactively, or wait for the one installed to fail? I'm thinking I don't fix what isn't broken, but then I don't want to be stranded 100+ miles from home either Sounds like I could still be stranded with a VDO special 15-20k miles from now anyway Last edited by 1QwkEvo; 05-09-2017 at 02:35 PM.. |
05-09-2017, 02:44 PM | #12 |
Rep 2,825
ok first off dont be changing shit thats not broken to begin with
I've heard of people getting more issues changing a perfectly good pump with a new one rather then just leaving it alone |
05-09-2017, 02:46 PM | #13 | |
Rep 405
With that said, I'd take my chances with the crack as you can still drive it, because, at least in my case, it was hairline cracks and the leaks were minimal. I drove for more than month before replacing as the coolant actually leaked out slowly, only having to top off once a week or so. |
05-09-2017, 03:05 PM | #14 |
Rep 791
That job is not the easiest in the world so I would personally get the right part without a crack. For some parts it makes sense to get one from a parts store where you can see it before you buy.
2011 BMW M3
2008 BMW 335i- MHD STG 1+ |
05-10-2017, 08:35 AM | #15 | |
Rep 56
As a 25+ year Mitsubishi guy, I agree with this 100%, however, this is my first e90 and I've heard such horror stories with these pumps. I just don't want myself and my family stranded in the middle of nowhere... Yet the car is so nice I want to use it for trips |
05-10-2017, 08:45 AM | #16 |
Rep 7,215
keep the VDO pump in the trunk, so at least you'll have the parts on hand if you need to do an emergency repair in the middle of Hicksville, Nebrahoma.
Otherwise I agree there's not much point in replacing a working pump with one that seems just as likely to fail anyway. |
05-10-2017, 04:34 PM | #18 |
Rep 7,215
no, the N52 pump is only 200w, the N54 pump is 400w. it's not directly bolt-on anyway.
it seems like it some manufacture would figure out people would be willing to pay for an N54 pump in a metal housing like the N52.. Maybe you guys should start contacting some different companies? |
05-11-2017, 08:54 AM | #19 | |
Rep 56
I was however unaware of the difference in output, that's unfortunate. So what year range do these plastic housing pumps extend to? There would have to be a large demand for manufacturers to gear up to produce these.... |
05-11-2017, 12:18 PM | #21 | |
Rep 14,829
Wonder if OEM has the same crack.... dunno what they get to ship and seems to be made by Continental and has a core https://parts.bmwofsouthatlanta.com/...517632426.html edit: no core, $398 OEM https://getbmwparts.com/parts/index....&siteid=214672 |
05-12-2017, 12:48 AM | #22 | |
Rep 2,109
BMW OEM: https://www.ecstuning.com/b-genuine-...p/11517632426/ VDO: https://www.ecstuning.com/b-vdo-part...517632426~vdo/ Vemo: https://www.ecstuning.com/b-vemo-q+-...517632426~veq/ I have seen pictures of ones sold under Gates name also, again same pump. |
