Help, shredding through tires! even after alignment
04-30-2017, 02:39 PM | #1 |
Rep 1,099
I am going through my 3rd set of front tires because the insides have gotten completely worn out before the rest of the tire. I ran 0 toe for a bit and quickily realized my mistake, but now i have been back to running toe in but still went through another set of front tires, so the issue is not resolved. please help! i've ran this much camber and toe in before and did not have issue so im not sure what is going on here but i can't afford to keep changing my front tires
I got my m3 control arms installed in July 2014 and have drove 40k miles on them, not sure if these bushings fail this fast? I've gone to two reputable shops and they say my bushings and suspension is fine.. i also get a slight vibration above 80 mph so i'm not sure if that is related. two different shops have confirmed my wheels are balanced as well so Last set of tires i went through: Same thing happening to current set (left and right front tires): Last edited by iturbo_bmw; 05-01-2017 at 12:15 PM.. Reason: updated pictures |
04-30-2017, 02:58 PM | #2 |
Life is better with burnouts
99
Rep 611
the 2.5 degrees of camber isnt helping you.
04-30-2017, 03:36 PM | #6 |
Rep 3,778
Drives: '11 328i '19 M6
The camber's fine, I run 3.8* with zero wear even though toe is set negative. It does look like it's rubbing on something, usually inner wear shows over a wider area. How many miles on the upper strut mounts? On the struts themselves? How much play in the steering?
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
feuer4277.00 |
04-30-2017, 03:38 PM | #7 |
Rep 3,778
Have you driven the car around the block a few times after an alignment and then had the same shop check it again? Better way to see if there's something going on with the arms and bushings, etc. And is this symmetric across both front tires?
feuer4277.00 |
04-30-2017, 05:37 PM | #9 |
Rep 545
The thing is if that is happening to only 1 tire then yes we could have said it's something rubbing or something is sticking out of wheel well and causing that, BUT OP said it's his both front tires - hence it can't be a coincidence that simultaneously both front have something wrong (like a loose bushing etc)
Op do you have coilovers? Is it possible you are lowered too much and in addition your M3 arms are messing up with camber much more than -2.5? |
04-30-2017, 05:44 PM | #10 | |
Rep 3,778
ThugzZ BunnY681.50 feuer4277.00 |
04-30-2017, 05:55 PM | #11 | ||
Rep 1,099
i had this suspension (tck coilovers and vorshlag camber plates) installed at the same time as m3 control arms - which was in July 2014 and have driver 40k on them There is very little play if at all. just some steering wheels vibrations above 85mph I think the shop usually does that during the alignment, but i haven't noticed any big differences in the past between alignments |
04-30-2017, 06:01 PM | #12 | |
Rep 3,778
The vibration at 80mph is telling, wondering if the nuts holding the plates in were overtorqued or if there is some wear that isn't obvious until you can unload the spherical joint in the plate.
04-30-2017, 06:06 PM | #13 |
Rep 1,099
I've had the shops check the bushing and they all said they were fine. i can try to get down there and check myself, although i dont know what to look for lol. Do i just check to see if there is any play in the suspension components?
04-30-2017, 06:08 PM | #14 | |
Rep 1,099
04-30-2017, 06:17 PM | #15 |
Rep 3,778
Yes, that's them. I've followed the torque spec in Bentley's but it never seems to hold. No idea if the shop used an impact driver, lightly, or some Loctite, but the last couple of times they didn't need torquing in the paddock before each run. The bolt plate isn't all that heavy duty and the body's relatively thin so it's easy to deform things, depending on which tower brace you have. Might be helpful to check to see if the camber setting is the same on both plates, look at the index markings and see if the pointer is on the same ones on both sides. Caster is set with bolt-in locations so it can't get mucked up and your caster/SAI settings are symmetrical so it's not an issue anyway.
04-30-2017, 07:40 PM | #16 | |
Rep 545
OP one more time I'm asking you - do you have same worn pattern on your other front tire? |
05-01-2017, 10:09 AM | #17 | |
Rep 3,778
Someone with a similar problem, might want to ping feuer, should be able to help.
05-01-2017, 12:04 PM | #18 |
Rep 1,099
Hey guys, I took pictures of the current condition of the front wheels, I had these tires put on right after the alignment that is pictured in the first post. one pic for each left and right front wheel. as you can see, the tire wear is just on inner portion of the tire only
05-01-2017, 12:07 PM | #19 | |||
Rep 1,099
05-01-2017, 01:12 PM | #20 | |
Rep 9,209
-can you post photos form the camper plates? -does you car pull when you brake? -have you noticed increased steering effort at lower speeds? I suspect issues with caster, either from mis-adjustment or failing suspension components. If this is adjustable on your plates go with less positive caster as more positive caster will pull toe when wheels are turning. |
05-01-2017, 02:24 PM | #21 |
Rep 545
I have no doubt it's a incorrect camber (negative) and toe that does that wear. Question is what component of suspension is causing excessive misalignment? Could be bushing, saggy springs, but whatever it is it has to be on both sides - that is really strange as i doubt bushings can go bad simultaneously on both sides. Something doesn't add up here
P.S. OP just to take obvious stuff out of suspicion - tires are NOT rubbing on the strut right? |
05-01-2017, 02:52 PM | #22 | |
Rep 3,778
Tags |
alignment, inside wear, tire, tire wear |
