E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Need advice with headlight LED bulbs
Reply
      05-05-2017, 06:42 PM   #1
amaksoud
Drives: 2009 320i
Hello,
I recently replaced my halogen headlight bulbs with LED bulbs. The outcome is totally worth the extra cost, however, the bulbs flicker every 3 to 5 minutes as long as the headlight switch is not on the off position.
I'm not sure why this happens and don't know if it could be of any harm.
Any advice ?
      05-05-2017, 07:20 PM   #2
Underground6t9
Underground6t9's Avatar
317
Drives: BMW 335xi, Lexus is250
You need a resistor
      05-05-2017, 07:25 PM   #3
6ixSpd
Save the manuals!
6ixSpd's Avatar
6033
Drives: '16 M3, '23 718 Spyder
Or code out the warm/cold checks.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
      05-05-2017, 07:32 PM   #4
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
Originally Posted by Underground6t9 View Post
You need a resistor
Resistor won't help with the flicker, only help with bulb warnings.
You need to code out the warm and cold bulb checks for any aftermarket LED bulbs to prevent flickering.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit
M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear
      05-05-2017, 08:11 PM   #5
amaksoud
Drives: 2009 320i
Thanks for the reply.
What these warm/cold bulb checks are for ? Will coding them out impose any risk ?
      05-06-2017, 12:41 AM   #6
VTECaddict
Where'd my VTEC go?
VTECaddict's Avatar
Drives: 06 330i 6MT
That's how the car checks to see if a bulb is bad or not. It sends a quick power signal to the light to measure the current for that circuit. With regular filament bulbs, the quick power signal isn't enough to produce visible light, but LEDs turn on instantly and use much less power, so the quick power burst produces a visible light flicker.
No harm in coding out the checks, other than the car won't be able to tell you if the bulb is bad. You'll have to check the bulbs manually if you want to see if they are burnt out.
      05-06-2017, 06:19 AM   #7
amaksoud
Drives: 2009 320i
@VTECaddict thanks a lot for the explanation
Reply
e90post
