Reseated battery and lost all power
05-09-2017, 10:34 AM | #1 |
Rep 46
Drives: 2007 328xi E90 Sedan Graphite
Not very long ago, I replaced my battery, rear junction box, and main relay because I had no power, and it was fine for a few months until last night when I replaced the IBS due to a communication error. The battery was not fastened down, so I lifted and moved it around a bit to be able to get it in the right spot. I attached the new IBS/Neg cable, and did not get a few big sparks when it first connected. I have no power anywhere now.
I tried my old junction box and old IBS after that and it's still behaving this way, the battery is fine (12.67v, but dropped to 12.56v overnight). I'm still not getting those big electric sparks from the neg pole whenever I attach the cable (just a few very small static electricity size sparks. I must have damaged something while reseating the battery. Does anyone know what could've happened? I have a multimeter for testing. Last edited by Kizelio; 05-09-2017 at 10:40 AM.. |
05-09-2017, 11:35 AM | #2 |
Rep 13,122
Is the cable at the battery pushed all the way down
on the terminal before you tighten tension screw. Is there 12 volts at all the connection points on the battery distribution box and under the hood. Did you pull out or break any of the cables on the battery distribution block ? Is the IBS still attached and serial bit data line still attached. Last edited by ctuna; 05-09-2017 at 11:40 AM.. |
05-09-2017, 11:53 AM | #3 |
Rep 3,898
Drives: 330i, 135i
Did you check Fuses?
05-09-2017, 12:40 PM | #4 | |
Rep 46
Can you tell me where to check under the hood? |
05-09-2017, 12:42 PM | #5 |
Rep 46
05-09-2017, 02:20 PM | #6 | |
Rep 46
05-09-2017, 02:51 PM | #7 |
Rep 13,122
How about check in power at the fuse box behind the Glove.
Then at the OBD port. electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU What about on the other side of the exploding link that shuts down engine +12 when your in an accident. Last edited by ctuna; 05-09-2017 at 02:56 PM.. |
05-09-2017, 06:52 PM | #8 | |
Rep 46
05-09-2017, 07:23 PM | #9 |
Rep 13,122
There are many more like these search for e90 bst cable. Last edited by ctuna; 05-09-2017 at 09:21 PM.. |
BimmerGeeks1180.00 |
05-11-2017, 12:55 AM | #10 | |
Rep 46
05-11-2017, 12:58 AM | #11 |
Rep 13,122
Should be easy enough to check with and ohmmeter.
Or you could just check the voltage at both ends when its plugged in. |
05-11-2017, 12:56 PM | #12 |
Rep 46
Tags |
battery, fuse, ibs, junction, power |
