E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Struggling to resolve an E90 335i In limp mode!!! (see below)
Reply
      05-20-2017, 01:03 PM   #1
F9SHK
F9SHK's Avatar
Drives: 335I E90
Question Struggling to resolve an E90 335i In limp mode!!! (see below)
Driving home and suddenly my Car went into limp mode, DSC faults came up also and the car was really rough on Idle (see video).
I pulled up the following codes,
2CEC: Throttle valve controller Jams briefly
2CED: Throttle valve controller Jame permanently
2CEF: Throttle valve activation
2D09: Throttle supply not correct
3100: charging pressure control switch off (I think this may be separate)
Other notable symptoms,
Engine surging
Slight Oil dripping from the exhaust
Oil in the engine bay (This started prior to the fault)
My initial thoughts were to take off the throttle body and clean it and try to trace the oil leak which I feel maybe a cracked pipe.
does this sound like a good place to start and has anyone had a similar problem?
Jake
Car E90 335i N54 2007, 80,000miles
Video:
      05-20-2017, 01:50 PM   #2
zooch7
Drives: 08 335i
I had a similar issue with mine. I removed it and wiped down really good. Havent seen any issues since .
      05-20-2017, 01:58 PM   #3
F9SHK
F9SHK's Avatar
Drives: 335I E90
The N54 only has one throttle body right?
Jake
Reply
Tags
limp mode, n54 335i, oil leak, rough idle, throttle actuators
e90post
