E90Post
Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Calling a few e90xi users
Reply
      05-28-2017, 01:06 PM   #1
coolephelps
Drives: 06 e90 & 08 e92
So, big day. Kw v1 coils= check. 205 55 16 tires= check. Wait, no sorry! New avant garde 355 18x8 et35 wheels(or F10 M5 wheels)= check and mate.
Problem is I have no clue on what tires to use. I'm hearing square, staggered? With the square should I run a 225 40 18? Staggered 225/40 255/35? With the wider 255 I don't know if I can lower the car like I want.
Also, what about understeer concerns with a lowered vehicle and staggered setup? Relatively inexpensive tire brands? Any inputs?
      05-28-2017, 04:37 PM   #2
StevenY.
///M
StevenY.'s Avatar
Drives: 10' SG e92 335i
You can run staggered but it has to be within 1%.
[img]http://www.e90post.com/forums/attach...1&d=1415238814[/img]
      05-29-2017, 03:08 AM   #3
stelvio
Drives: E91 335xi + E70 X5d
^ THIS
Also, you can go to the "Wheels and Tires Forum" section on this website where you'll find the wheel/tire calculator up top and you can calculate what you can or cannot put on your car...it helps for calculating spacers/etc...
      05-29-2017, 10:12 AM   #4
terryd5150
Head Fry Cook at McBurgertown
Drives: 2015 435i M-Sport 6MT
I ran 225/40/18 fronts and 255/35/18 rears (Bridgestone runflats) with no problems on my XI.
You could run 225/40/18 on all four wheels, if you need.
      05-29-2017, 10:52 AM   #5
SamM3VT
Drives: 2008 335xi, 2004 M3
+1
I run 225/40/19 up front and 255/35/19 in the back, same setup on my 335xi
      05-29-2017, 10:24 PM   #6
NiNeTyOne
Touring cars rock
Drives: e91 330xi / 997 GT3 Cup
Does your car understeer? If so, why would you want to further unbalance the grip in favor of the rear?
Sportwagon Daily: I've done some stuff.
      05-30-2017, 04:59 PM   #7
fazman
Drives: 335 e90
Let me save you some time and just help you get to the end. While I was in the East coast (NJ/NY) I had ran the stock square setup 17" rims on my e90 335xi and everything was fine. I eventually upgraded to 18" style 162's staggered cuz i liked those rims better and thought the wider rears would be great! I went thru two sets of MPS AS3's in this setup. I even switched my front rims from the 18x9 --> the 18x9.5 width rear rims on a front smaller tire 225/40/18 for a little bit of a stretch look cuz i like the deeper convex look of the rear rims (so I had a square set of rear rims 18"x9.5" on staggered tires FRONT: 225/40/18 & REAR: 255/35/18). As Michelin had stated my rear tires wore down twice as fast as my fronts did. Last week I put on a new set of tires because my MPS AS3's were 1mm tread depth remaining on the rears and 6mm remaining on the fronts (keep in mind I'm an XI and started with 4 new tires all around). I could totally hear the transfer case humming away as I was driving which was a cause for concern to me.
So NOW (as of last week). I am on style 162's rims, square rear rims (meaning four 18"x9.5" rims), and four square tires MPSS (I now live in the one season SoCal weather) 225/40/18's and I can safely say... OMG I loveeeeeeeee these MPSS and I love being square tires so I can rotate them.
Advice to you: since you are AWD/XI, stick with a square tire setup
      05-31-2017, 05:42 AM   #8
stelvio
Uhh....You guys realize that the manufacturer [BMW] sells their XI's w/ staggered setup right? Like E92's?
$0.02 = I never had any issues on my XI.
      05-31-2017, 03:55 PM   #9
fazman
Drives: 335 e90
Yes they do, however, as stated in my experience... you have a HUGE delta in wheel rotations between the FRONT's and REAR's which is not very friendly to AWD systems. I had a 50% difference in rotations and got lucky that I didn't blow out my transfer case (I could hear the humming and "feel" a difference). Now that I am back to square with all the same wheel rotations per minute... the car is very smooth.
You can roll your dice as you wish, but I don't recommend staggered for the OP since his intention is NOT to track the car. I never tracked my car either... i did my experiment on two sets of tires.
      06-02-2017, 12:36 PM   #10
coolephelps
Nice experiment fazman. Yes, I've decided on the square set. I'll use the 225/40 18. That's the size BMW uses on their front staggered setups. I'm not tracking the car as presumed. Just a nice lowering using the kw v1 setup on some m5 wheels. Stelvio had a point on the staggered set. BMW does make this. However, not sure if it makes a difference but I think they only stagger the sport package vehicles. Sport suspension and seats. Not sure if anything else is different than the non sport package. But mine is the standard 6spd with the 16" wheels on it. Now, if I can just find some seats I may turn mine into the sport package
      06-05-2017, 10:53 AM   #11
Cory S
Cory S's Avatar
Drives: 2011 335i-X
I run 235/40/18 square on a 18X8.5" wheel, on my E90 X-drive. They are wearing very little.
Previously ran staggered Michelin PSS's. 225 up front, 255 out back. They too also wore great. 24K miles out of the rears.
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
      06-07-2017, 01:43 AM   #12
coolephelps
Yea. I finally choose the bfgoodrich g force comp 2 tires in a 225 40 18x8. I'm hoping I get the same results out of my tires. Especially being lowered about 2.5" give or take an .5".
      06-07-2017, 07:20 AM   #13
ObsidianX
Drives: 2017 M2 (LBB, 6MT)
I'm also on 235/40R18 square using 8.5 inch rims. This is on a LCI E90 xDrive. Also running K&W V1 coilovers like you plan. No problems at all.
2017 BMW M2 (LBB, 6MT)
2011 BMW 335i xDrive (N55)
2006 BMW X3 3.0 (M54B30) - Sold 5/17
      06-07-2017, 08:21 AM   #14
Hearf
Drives: 2009 E90 335xi
I'm running 255/35/18 on 9" wide ET30 wheels. LCI E90 xDrive with a mild drop lowered on koni yellow + H&R sport springs.
      06-07-2017, 09:07 AM   #15
max_330i
max_330i's Avatar
Drives: 2006 BMW 330i
...So NOW (as of last week). I am on style 162's rims, square rear rims (meaning four 18"x9.5" rims), and four square tires MPSS (I now live in the one season SoCal weather) 225/40/18's and I can safely say... OMG I loveeeeeeeee these MPSS and I love being square tires so I can rotate them.
I thought Style 162 rears were 18x8.5? Nice job though, where did you pick up the two rears to square it up? I would love to have a square set of the wider 162's but they are hard to come by.
2006 330i 6MT Jet Black / Black
      06-08-2017, 02:10 PM   #16
fazman
Drives: 335 e90
My bad... you are correct, stock Fronts are 18x8 rims and stock Rears are 18x8.5
I'm originally from the east coast... so just look in the regional section. I basically had to pick up 2 loose rear rims as they came up for sale. I originally picked up a set of staggered style 162's from another friend. Once i learned I "could" install the rear wider rim on a front standard size tire (has a little stretch and poke but works)... thats when I said... hey lets try it and it has worked for me since.
I ended up sending all those bent/scratched/roughed up rims to a shop in NJ to get straightened and powder coated back to mint condition (http://needpowdercoating.com)
I would highly suggest having your rims shipped to them for repair/powder coating... because the shop is in a very rough place (If you didn't have bent rims before going to them... you are sure to have bent rims when you arrive at their shop some of NJ's finest roads)
max_330i340.00
      06-09-2017, 09:28 AM   #17
max_330i
max_330i's Avatar
I appreciate the tips Enjoy those square 162's. I will continue looking for my own set but remain super jealous of you until then.
fazman681.00
Reply
e90post
