Remove engine cover for better cooling?
05-29-2017, 11:47 AM | #1 |
Rep 221
'08 E93, always hot here in Texas. Will the engine run cooler if I remove the engine cover?
Any other downsides like noise or accumulated dirt? Mikey |
05-29-2017, 02:20 PM | #2 |
Where'd my VTEC go?
481
Rep 6,067
I don't think it will make any measurable difference. Don't worry about it unless the car is overheating all the time. And if it is overheating all the time, something is probably broken.
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
05-29-2017, 08:50 PM | #6 |
Rep 790
I know that on a 335i, removing the cover is bad.
It protects the engine from water which can mess up your ignition coils. I saw a video on that once. |
05-30-2017, 06:34 AM | #8 |
Rep 177
Weight reduction, bro.
Bimmer 808170.00 |
05-30-2017, 06:59 AM | #9 |
Rep 1,082
Runs much cooler with hood delete
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
Antetokounmpo1551.50 Bimmer 808170.00 |
05-30-2017, 08:08 AM | #10 |
ahat
1036
Rep 2,592
Get MHD and set WP to sport. My oil temp is about 20 degrees lower just that change alone.
edit nvm - see you got a 328...sorry.. head north son.
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
05-30-2017, 12:32 PM | #11 |
Hoonigan
6893
Rep 3,001
Drives: '09 328i, '98 Wrangler
Talking about the top cover that goes over the valve cover or the plastic shield on the bottom?
I removed the one on the bottom because I like to know when a vehicle is leaking. Plus my GF managed to hit something and rip half of it off anyway.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
05-30-2017, 02:58 PM | #12 |
Rep 639
05-30-2017, 07:47 PM | #13 |
ahat
1036
Rep 2,592
weird part is today it was almost to the same. within 5 degrees.
So I'm still trying to pin this down.
05-31-2017, 05:48 AM | #15 |
Rep 76
05-31-2017, 10:31 AM | #16 |
Rep 937
05-31-2017, 05:29 PM | #17 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
That's better. At most it's a couple degree difference. The reason I do it is for easy, quick access to the plugs and coils.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
06-05-2017, 11:19 AM | #19 |
Rep 1,163
I run without the rear plastic top of engine cover, and without the plastic catch tray underneath. Oil temperatures dropped 8-10*F, and underhood temps dropped 18-25*F.
Without the Cowl cover, these temps drop even lower, but I normally run with it on.
2011 335i X-drive 6AT / Pure turbo / 500AWHP/526TQ
