06 330i - Can't chirp second. Tuneup advice please.
06-06-2017, 03:30 PM | #1 |
Rep 562
I have a 2006 330I. N52 motor with the fancy manifold everyone talks about.
Sometimes the car misfires and so I think it may need coils, but it runs fine most of the time. 167,000 KM (about 100K Miles) Brand new NGK plugs Freshly cleaned K&N Charcoal delete Dinan Exhaust Ran seafoam before plug change Ran many bottles of injector cleaner from dealership Did a two stage oil flush with dealership special fluids which decarbonize Checked eccentric shaft sensor and changed gasket on it. There was no oil. Checked top DISA , no play. Not sure how to reach bottom DISA easily. Cleaned VANOS solenoid, they look fine but no way to tell. Sometimes it shows a misfire on cylinder 5 if going WOT at low RPMs. Most of the time nothing. Was very misfirey and shakey for a few KM after being stored for 2 months... then it went away. Any tips are welcome. Can't chirp second ever, and it constantly feels underpowered. My other car is an e92 m3 so I'm not sure if I'm crazy or not. My old e46 ZHP would chirp second on every shift even at 307,000KM Last edited by The-Traveler; 06-06-2017 at 04:10 PM.. Reason: Added codes. |
06-06-2017, 03:55 PM | #5 |
[Oo=||=oO]
1105
Rep 2,470
Not sure if you are trolling or not.
Other with cold tires, you will not be able to break the rear end loose, esp with failing coil. Don't know what you are expecting from 210whp on a good day? |
06-06-2017, 04:00 PM | #6 | |
Rep 562
Generally the motor feels underpowered and this was the only metric I could think of to reliably benchmark it. (on the web, for free) I'm running an old (almost bald,) set of DWS all seasons. Not Pilot Sport Cups lol... it should break loose no problem. |
06-06-2017, 05:25 PM | #7 |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.09] |
06-06-2017, 07:07 PM | #8 |
Rep 611
yea CDV is not engine related.
N51- PI - PE - ESS Tuned - SSK - CDV Delete - AFE Header - B12 - Mfactory LSD
06-06-2017, 07:27 PM | #9 |
Rep 37
Drives: 2001 540iT
Swap the misfiring coil and see if the problem shifts cylinders. I'd just buy 6 new ones.
06-06-2017, 07:40 PM | #10 |
Rep 12,570
06-07-2017, 04:52 AM | #11 |
Rep 1,017
Test your coils with a ohm meter to see if there within spec before buying, swap with number 1, add some high octane gas, you may have moisture from sitting. Sometimes when moving a coil over to the next, may give a false reading, jump it to the furthest away to eliminate it.
06-07-2017, 07:03 AM | #12 |
Rep 1,191
Drives: 2009 BMW 328i Wagon
06-07-2017, 08:52 AM | #14 |
Rep 922
I'm surprised nobody has asked this, what kind of tires are on the cars in question?
I had a thread the other day about buying a set of tires to replace my Bridgestone RE-11. I won't go into unnecessary levels of detail, but the treadwear rating is 200, meaning they are soft and gummy. If you're running a comparable summer performance tire, correctly inflated and properly warmed up, you will have a hell of a time "chirping" the tires in any gear with 255 hp at the crank and a bad coil.
2006 330i 6MT Jet Black / Black
06-07-2017, 09:16 AM | #15 | ||
[Oo=||=oO]
1105
Rep 2,470
max_330i340.00 |
06-07-2017, 09:20 AM | #16 |
Rep 922
Whoops, you are right, I should have read more carefully.
06-07-2017, 04:30 PM | #17 |
Rep 947
Make sure the DISA valves are working correctly. The flap is slipped onto a plastic shaft with a hex shaped base to lock the flap in place. It's very common for the hex base of the flap to wear away and render the flap inoperable. There are no codes thrown since the motor is still operational.
You'll have to remove the manifold to access the inner DISA but the outer can be pulled by just removing the airbox. EDIT: Whoops I see you already checked |
06-07-2017, 05:34 PM | #18 |
Rep 525
maybe the clutch doesn't hold that well anymore and slips a little bit, that's pretty much the only occasion I wasn't able to chirp into second in any manual car I've owned
06-07-2017, 07:39 PM | #19 | |
Rep 562
I've ordered Coils so let's see. |
06-07-2017, 08:20 PM | #20 |
Rep 699
Drives: 2010 E90 BMW 328i
My question is why do you even drive the 330 if you have an m3
Murdered 2010 E90 328i
ESS VT1+ | BMW PE | 3IM | K Sport Kontrol Pro |
06-07-2017, 08:28 PM | #21 |
Rep 1,413
