06-12-2017, 06:33 PM | #1 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Varis Lip Install Help
Hi,
I am the proud owner of a RW Carbon Varis style lip that I am going to install on my 2015 335i with the M Sport package. The problem is that it didn't come with directions to help the novice person like me. I'm hoping there is someone with a wealth of knowledge about installing these. I have learned that my bumper is held on by a boat load of push pin rivets and four tiny metal screws. I've also learned that some of the rivets can't be installed before you mount the lip if you want the lip to fit flush. Plus I will have to buy longer push pin rivets for the install because the thickness of the lip eats up the length of the original rivets. One question I have is what size of self tapping screws do you use for the extra bolts? I was told by their customer service to use one inch long screws. I think I'm going to go shorter. It seems these would be too long. I can't wait to get the lip installed. I have the rear deck spoiler and extremely happy with it. Thanks in advance for everyone's help. |
06-13-2017, 09:10 PM | #2 |
Rep 1,659
Got it done finally. If you can do this on a lift you'll be way ahead of the game.
Just be prepared to make a trip to the hardware store.
Rick
06-14-2017, 05:46 AM | #4 |
Rep 1,659
Gotta go to the car wash first.
No rain and it's a dust bowl around here. Maybe today or tomorrow.
Rick
06-19-2017, 02:58 PM | #5 |
Rep 1,659
Well I finally made it to the car wash.
This will give you some idea of what it will look like. I'm pretty happy with how it turned out. It was a pain in the butt to install with no instructions for me. You're not sure what to take off or leave on as far as fastening points. Just plan on making a couple of trips to the hardware store!! |
06-19-2017, 03:18 PM | #6 |
Rep 2,981
Drives: 2013 BMW F30 EBII
Looks great! Makes me wish I hadn't sold it to you! haha
Drives: 2011 Porsche 958, 1965 Chevy C10, 1988 Porsche 944 Sold:2010 e90 Montego Blue, 2013 F30 EBII, 2013 Tangerine Scream Ford Focus ST, 2006 Mini R50,2004 VW Touareg, 2012 Camaro Convertible, 2008 Porsche 911 Convertible, 2007 Corvette, 2004 BMW e64 convertible, 2000 Dodge Dakota, 1999 Ford F150, 1999 Porsche Boxster, 1999 Ferrari Modena, 1992 BMW e36, 1990 Nissan 240sx, 1979 Celica, 1974 Mustang II
My Build Thread |
06-29-2017, 05:28 PM | #8 |
Rep 1,659
The first thing I did was to clean the bottom of the bumper. Second I held up the spoiler and figured out I had to remove all the attachment hardware thinking I would be able to reuse them. I reinstalled the fasteners where there were no holes were provided for on the spoiler. I now see that the spoiler isn't going to fit flush with the bumper. Now I take those out and try to attach the spoiler to the bumper using the factory push pins. Guess what? They're not long enough. So I make a trip to the hardware store which is about six miles away and buy some longer pins and enough one inch long sheet metal screws that fasten the front portion of the spoiler to the bumper.
Now I get home and get underneath the car on my faithful Craftsman creeper. For some unknown reason the pushpins won't close. So another trip to the hardware store. I ended up buying four one and a half inch long bolts plus washers and nylon locknuts for the four holes in the rear middle of the bumper. I also ended up with eight #8X3/4 self tapping screws to fasten the front portion of the spoiler to the bumper. The only things I used factory was the two outer 8mm bolts and two pushpins. One thing though, it's not coming off now. And it does look good. I'm happy with it but I like function with form. I love RW Carbon. They are awesome and knowledgeable about their products. That being said I would go with the M Performance one from BMW. At least it has directions and the necessary hardware. I know they don't have the Varis style and it costs a little more. I guess at 57 years old and not so mechanically inclined I appreciate directions and all the pieces needed to do the job. I'm sure not being able to use all the factory mounting points won't make a huge difference. It would make me feel a little better about installing a product that is supposed to be designed for the vehicle you're installing it on was made to use all the factory mounting points.
Rick
06-29-2017, 10:26 PM | #9 | |
Rep 2,319
06-30-2017, 06:06 AM | #10 | ||
Rep 1,659
I was able to use one factory pushpin and the 8mm screws at the outer edges. The rest of the lip is so thick the factory pins won't work.
Rick
06-30-2017, 07:26 AM | #11 |
Rep 2,046
I used the longer pop-in plastic pins from BMW. Nice work, now you really have to slow down for the speed bumps
06-30-2017, 08:57 AM | #12 | |
Rep 2,319
06-30-2017, 12:52 PM | #13 | ||
Rep 1,659
Rick
eddiehatchblack40.00 50shadesofhockenheim2163.00 |
07-14-2017, 10:42 AM | #14 | |
Rep 46
You also stated you bought 8 self-tapping screws, did you drill new holes through the spoiler and use all 8 of these in addition to the 4 1-1/2 inch screws? A little clarification would be amazing! Thanks! |
07-14-2017, 12:05 PM | #15 | |
Rep 1,659
My recommendation is that you find someone with a lift unless you have a lot of dexterity. The four holes in the center were a real bitch for me. For the remaining holes, I understand BMW may have some push style plastic rivets that may work. My dealer is 70 miles away. Not worth the drive. I couldn't find the correct length ones at my hardware store. You can probably also use metal rivets, but that's pretty permanent. There are already holes drilled into the spoiler for the front attaching nuts. Line the spoiler with the bumper and drill VERY small holes for each of them. That helps the screws start easier. I used 3/4 inch long sheet metal screws and they worked fine for me. I also recommend that you get some thin 3M double sided tape to use where the intake holes are. I didn't, but I think it would help. Use stainless steel hardware just in case you have to remove anything. No rust that way. In all honesty though, I would never do it again had I know what a pain in the ass it was. I would get the OEM M Performance one and do it. You get the same aerodynamic effect if your going for that. You don't the extra cooling as they claim because there is a cover to prevent mud splattering up. Therefore none of that "extra" air gets to the engine anyways. And you get hardware and instructions with the M Performance one. I grant you the end result looks nice. I'm not sure the end justified the means. |
